AnimationSampler.h
8#include <cstdint>
9#include <string>
10
11namespace CesiumGltf {
16struct CESIUMGLTF_API AnimationSampler final
21 static constexpr const char* TypeName = "AnimationSampler";
22
31 inline static const std::string LINEAR = "LINEAR";
32
36 inline static const std::string STEP = "STEP";
37
44 inline static const std::string CUBICSPLINE = "CUBICSPLINE";
45 };
46
54 int32_t input = -1;
55
63
67 int32_t output = -1;
68
75 int64_t getSizeBytes() const {
76 int64_t accum = 0;
77 accum += int64_t(sizeof(AnimationSampler));
79 int64_t(sizeof(CesiumUtility::ExtensibleObject));
80
81 return accum;
82 }
83};
84} // namespace CesiumGltf
Known values for Interpolation algorithm.
The animation's interpolation is computed using a cubic spline with specified tangents....
The animated values are linearly interpolated between keyframes. When targeting a rotation,...
The animated values remain constant to the output of the first keyframe, until the next keyframe....
An animation sampler combines timestamps with a sequence of output values and defines an interpolatio...
int32_t output
The index of an accessor, containing keyframe output values.
int32_t input
The index of an accessor containing keyframe timestamps.
std::string interpolation
