AccessorSparseIndices.h
8#include <cstdint>
9
10namespace CesiumGltf {
16struct CESIUMGLTF_API AccessorSparseIndices final
21 static constexpr const char* TypeName = "AccessorSparseIndices";
22
28 static constexpr int32_t UNSIGNED_BYTE = 5121;
29
31 static constexpr int32_t UNSIGNED_SHORT = 5123;
32
34 static constexpr int32_t UNSIGNED_INT = 5125;
35 };
36
43 int32_t bufferView = -1;
44
48 int64_t byteOffset = 0;
49
57
64 int64_t getSizeBytes() const {
65 int64_t accum = 0;
66 accum += int64_t(sizeof(AccessorSparseIndices));
68 int64_t(sizeof(CesiumUtility::ExtensibleObject));
69
70 return accum;
71 }
72};
73} // namespace CesiumGltf
Known values for The indices data type.
UNSIGNED_INT (5125)
UNSIGNED_SHORT (5123)
UNSIGNED_BYTE (5121)
An object pointing to a buffer view containing the indices of deviating accessor values....
int32_t componentType
int64_t byteOffset
The offset relative to the start of the buffer view in bytes.
int32_t bufferView
The index of the buffer view with sparse indices. The referenced buffer view MUST NOT have its target...
