Properties.h
8namespace CesiumTilesetJson {
12struct CESIUMTILESETJSON_API Properties final
17 static constexpr const char* TypeName = "Properties";
18
23 double maximum = double();
24
29 double minimum = double();
30
37 int64_t getSizeBytes() const {
38 int64_t accum = 0;
39 accum += int64_t(sizeof(Properties));
41 int64_t(sizeof(CesiumUtility::ExtensibleObject));
42
43 return accum;
44 }
45};
46} // namespace CesiumTilesetJson
A dictionary object of metadata about per-feature properties.
Definition Properties.h:13
double maximum
The maximum value of this property of all the features in the tileset. The maximum value shall not be...
Definition Properties.h:23
Definition Properties.h:17
double minimum
The minimum value of this property of all the features in the tileset. The maximum value shall not be...
Definition Properties.h:29
Definition Properties.h:37
