ExtensionSchemaMaxarContentGeoJson Properties Value. More...
#include <Cesium3DTiles/ExtensionSchemaMaxarContentGeoJsonPropertiesValue.h>
Classes | |
| struct | Type |
| Known values for Expected datatype of the property value in the GeoJSON Feature's 'properties' object. More... | |
| std::string | id |
| Unique property identifier that corresponds to a property name in the GeoJSON Feature's 'properties' object. | |
| std::string | type = Type::Integer |
| Expected datatype of the property value in the GeoJSON Feature's 'properties' object. | |
| std::optional< std::string > | description |
| Human readable description of the property. | |
| std::optional< std::string > | unit |
| Unit of the specified property. | |
| std::optional< double > | max |
| Maximum allowed value for the property. Only applicable to integer and float types. When both min and max are specified, max must be greater than or equal to min. | |
| std::optional< double > | min |
| Minimum allowed value for the property. Only applicable to integer and float types. When both min and max are specified, min must be less than or equal to max. | |
| std::optional< bool > | required = std::optional<bool>() |
| If true, this property must be present in the 'properties' object of every GeoJSON Feature in the associated tile content. | |
| std::optional< CesiumUtility::JsonValue > | defaultProperty |
A default value to use when this property is missing from a GeoJSON Feature's 'properties' object. Shall not be defined if required is true. | |
| std::optional< std::string > | semantic |
| An identifier that describes how this property should be interpreted. The semantic cannot be used by other properties in the properties schema. | |
Definition at line 16 of file ExtensionSchemaMaxarContentGeoJsonPropertiesValue.h.
Definition at line 109 of file ExtensionSchemaMaxarContentGeoJsonPropertiesValue.h.
| std::optional<CesiumUtility::JsonValue> Cesium3DTiles::ExtensionSchemaMaxarContentGeoJsonPropertiesValue::defaultProperty |
Definition at line 94 of file ExtensionSchemaMaxarContentGeoJsonPropertiesValue.h.
| std::optional<std::string> Cesium3DTiles::ExtensionSchemaMaxarContentGeoJsonPropertiesValue::description |
Definition at line 63 of file ExtensionSchemaMaxarContentGeoJsonPropertiesValue.h.
| std::string Cesium3DTiles::ExtensionSchemaMaxarContentGeoJsonPropertiesValue::id |
Definition at line 49 of file ExtensionSchemaMaxarContentGeoJsonPropertiesValue.h.
| std::optional<double> Cesium3DTiles::ExtensionSchemaMaxarContentGeoJsonPropertiesValue::max |
Definition at line 75 of file ExtensionSchemaMaxarContentGeoJsonPropertiesValue.h.
| std::optional<double> Cesium3DTiles::ExtensionSchemaMaxarContentGeoJsonPropertiesValue::min |
Definition at line 82 of file ExtensionSchemaMaxarContentGeoJsonPropertiesValue.h.
| std::optional<bool> Cesium3DTiles::ExtensionSchemaMaxarContentGeoJsonPropertiesValue::required = std::optional<bool>() |
Definition at line 88 of file ExtensionSchemaMaxarContentGeoJsonPropertiesValue.h.
| std::optional<std::string> Cesium3DTiles::ExtensionSchemaMaxarContentGeoJsonPropertiesValue::semantic |
Definition at line 101 of file ExtensionSchemaMaxarContentGeoJsonPropertiesValue.h.
| std::string Cesium3DTiles::ExtensionSchemaMaxarContentGeoJsonPropertiesValue::type = Type::Integer |
Definition at line 58 of file ExtensionSchemaMaxarContentGeoJsonPropertiesValue.h.
Definition at line 21 of file ExtensionSchemaMaxarContentGeoJsonPropertiesValue.h.
| std::optional<std::string> Cesium3DTiles::ExtensionSchemaMaxarContentGeoJsonPropertiesValue::unit |
Definition at line 68 of file ExtensionSchemaMaxarContentGeoJsonPropertiesValue.h.
