Cesium3DTiles::ExtensionMetadataEntityMaxarContentGeoJson Struct Referencefinal
Enables loading optional metadata schema for GeoJSON properties. More...
#include <Cesium3DTiles/ExtensionMetadataEntityMaxarContentGeoJson.h>
Inheritance diagram for Cesium3DTiles::ExtensionMetadataEntityMaxarContentGeoJson:
std::optional< std::string > propertiesSchemaUri
 The URI (or IRI) of the external schema file for feature metadata.
static constexpr const char * ExtensionName = "MAXAR_content_geojson"
Definition at line 15 of file ExtensionMetadataEntityMaxarContentGeoJson.h.
int64_t Cesium3DTiles::ExtensionMetadataEntityMaxarContentGeoJson::getSizeBytes ( ) const
Definition at line 37 of file ExtensionMetadataEntityMaxarContentGeoJson.h.
◆ ExtensionName
const char* Cesium3DTiles::ExtensionMetadataEntityMaxarContentGeoJson::ExtensionName = "MAXAR_content_geojson"
Definition at line 24 of file ExtensionMetadataEntityMaxarContentGeoJson.h.
◆ propertiesSchemaUri
std::optional<std::string> Cesium3DTiles::ExtensionMetadataEntityMaxarContentGeoJson::propertiesSchemaUri
Definition at line 29 of file ExtensionMetadataEntityMaxarContentGeoJson.h.
const char* Cesium3DTiles::ExtensionMetadataEntityMaxarContentGeoJson::TypeName
Initial value:
"ExtensionMetadataEntityMaxarContentGeoJson"
Definition at line 20 of file ExtensionMetadataEntityMaxarContentGeoJson.h.
