ExtensionMetadataEntityMaxarContentGeoJson.h
8#include <optional>
9#include <string>
10
11namespace Cesium3DTiles {
15struct CESIUM3DTILES_API ExtensionMetadataEntityMaxarContentGeoJson final
20 static constexpr const char* TypeName =
21 "ExtensionMetadataEntityMaxarContentGeoJson";
24 static constexpr const char* ExtensionName = "MAXAR_content_geojson";
25
29 std::optional<std::string> propertiesSchemaUri;
30
37 int64_t getSizeBytes() const {
38 int64_t accum = 0;
39 accum += int64_t(sizeof(ExtensionMetadataEntityMaxarContentGeoJson));
41 int64_t(sizeof(CesiumUtility::ExtensibleObject));
42 if (this->propertiesSchemaUri) {
43 accum += int64_t(this->propertiesSchemaUri->capacity() * sizeof(char));
44 }
45 return accum;
46 }
47};
48} // namespace Cesium3DTiles
Classes for using 3D Tiles.
Definition Buffer.h:7
Enables loading optional metadata schema for GeoJSON properties.
std::optional< std::string > propertiesSchemaUri
The URI (or IRI) of the external schema file for feature metadata.
