Extension3dTilesContentConditional Dimensions Value. More...
#include <Cesium3DTiles/Extension3dTilesContentConditionalDimensionsValue.h>
| std::string | name |
| The name of the property that is used for defining the condition, to be used as one of the keys in the conditional content array items. | |
| std::vector< CesiumUtility::JsonValue > | keySet |
| The set of all values that appear in any condition. | |
Definition at line 16 of file Extension3dTilesContentConditionalDimensionsValue.h.
Definition at line 41 of file Extension3dTilesContentConditionalDimensionsValue.h.
| std::vector<CesiumUtility::JsonValue> Cesium3DTiles::Extension3dTilesContentConditionalDimensionsValue::keySet |
Definition at line 33 of file Extension3dTilesContentConditionalDimensionsValue.h.
| std::string Cesium3DTiles::Extension3dTilesContentConditionalDimensionsValue::name |
Definition at line 28 of file Extension3dTilesContentConditionalDimensionsValue.h.
Definition at line 21 of file Extension3dTilesContentConditionalDimensionsValue.h.
