Cesium3DTiles::Extension3dTilesContentConditional Struct Referencefinal
Defines the structure of the extension object that is stored as the 3DTILES_content_conditional extension in a tileset JSON, and that summarizes the conditions that appear in the contents. More...
#include <Cesium3DTiles/Extension3dTilesContentConditional.h>
Inheritance diagram for Cesium3DTiles::Extension3dTilesContentConditional:
std::vector< Cesium3DTiles::Extension3dTilesContentConditionalDimensionsValue > dimensions
 The dimensions of the conditions, each consisting of the name and domain of the respective property.
static constexpr const char * TypeName = "Extension3dTilesContentConditional"
static constexpr const char * ExtensionName = "3DTILES_content_conditional"
Definition at line 17 of file Extension3dTilesContentConditional.h.
int64_t Cesium3DTiles::Extension3dTilesContentConditional::getSizeBytes ( ) const
Definition at line 40 of file Extension3dTilesContentConditional.h.
◆ dimensions
std::vector<Cesium3DTiles::Extension3dTilesContentConditionalDimensionsValue> Cesium3DTiles::Extension3dTilesContentConditional::dimensions
Definition at line 32 of file Extension3dTilesContentConditional.h.
◆ ExtensionName
const char* Cesium3DTiles::Extension3dTilesContentConditional::ExtensionName = "3DTILES_content_conditional"
Definition at line 25 of file Extension3dTilesContentConditional.h.
const char* Cesium3DTiles::Extension3dTilesContentConditional::TypeName = "Extension3dTilesContentConditional"
Definition at line 22 of file Extension3dTilesContentConditional.h.
