Cesium3DTiles::ConditionalContent Struct Referencefinal
Defines the structure of 3D Tiles content for the 3DTILES_content_conditional extension. More...
#include <Cesium3DTiles/ConditionalContent.h>
Inheritance diagram for Cesium3DTiles::ConditionalContent:
std::vector< Cesium3DTiles::ConditionalContentItem > conditionalContents
 The array of content objects that have additional conditions associated with them, based on which they are activated.
static constexpr const char * TypeName = "ConditionalContent"
Definition at line 16 of file ConditionalContent.h.
int64_t Cesium3DTiles::ConditionalContent::getSizeBytes ( ) const
Definition at line 35 of file ConditionalContent.h.
◆ conditionalContents
std::vector<Cesium3DTiles::ConditionalContentItem> Cesium3DTiles::ConditionalContent::conditionalContents
Definition at line 27 of file ConditionalContent.h.
const char* Cesium3DTiles::ConditionalContent::TypeName = "ConditionalContent"
Definition at line 21 of file ConditionalContent.h.
