BufferSpec.h
8#include <cstdint>
9#include <optional>
10#include <string>
11
12namespace Cesium3DTiles {
17struct CESIUM3DTILES_API BufferSpec : public CesiumUtility::ExtensibleObject {
21 static constexpr const char* TypeName = "Buffer";
22
30 std::optional<std::string> uri;
31
35 int64_t byteLength = int64_t();
36
40 std::optional<std::string> name;
41
48 int64_t getSizeBytes() const {
49 int64_t accum = 0;
50 accum += int64_t(sizeof(BufferSpec));
52 int64_t(sizeof(CesiumUtility::ExtensibleObject));
53 if (this->uri) {
54 accum += int64_t(this->uri->capacity() * sizeof(char));
55 }
56 if (this->name) {
57 accum += int64_t(this->name->capacity() * sizeof(char));
58 }
59 return accum;
60 }
61
62protected:
67 BufferSpec() = default;
68 friend struct Buffer;
69};
70} // namespace Cesium3DTiles
Classes for using 3D Tiles.
Definition Buffer.h:7
BufferSpec()=default
Definition BufferSpec.h:48
The name of the buffer.
Definition BufferSpec.h:40
Definition BufferSpec.h:21
int64_t byteLength
The length of the buffer in bytes.
Definition BufferSpec.h:35
std::optional< std::string > uri
The URI (or IRI) of the file that contains the binary buffer data. Relative paths are relative to the...
Definition BufferSpec.h:30
