cesium-native 0.67.0
Classes for writing JSON. More...
Classes | |
| class | ExtensionWriterContext |
| A context for writing extensions where known extensions and their handlers can be registered. More... | |
| class | JsonWriter |
Wrapper around rapidjson::Writer for writing objects to JSON. More... | |
| class | PrettyJsonWriter |
| Implementation of JsonWriter that "pretty-prints" JSON to the output, formatted with new lines and indentation. More... | |
Enumerations | |
| enum class | ExtensionState { Enabled , Disabled } |
| The state of an extension. More... | |
Functions | |
| void | writeJsonValue (const CesiumUtility::JsonValue &value, JsonWriter &writer) |
| Writes the given CesiumUtility::JsonValue to the provided writer. | |
| template<typename TExtended> | |
| void | writeJsonExtensions (const TExtended &obj, JsonWriter &jsonWriter, const ExtensionWriterContext &context) |
| Writes the extensions attached to the provided object as a new JSON object. | |
| bool | hasRegisteredExtensions (const TExtended &obj, JsonWriter &jsonWriter, const ExtensionWriterContext &context) |
| Checks if the provided object has any extensions attached that have been registered with the provided ExtensionWriterContext. | |
strong |
| Enumerator | |
| Enabled | The extension is enabled. If the extension is a CesiumUtility::JsonValue or a registered statically-typed class it will be written to the serialized model; otherwise it will be ignored and a warning will be reported. |
| Disabled | The extension is disabled. It will not be represented in the serialized model at all. |
Definition at line 17 of file ExtensionWriterContext.h.
| bool CesiumJsonWriter::hasRegisteredExtensions | ( | const TExtended & | obj, |
| JsonWriter & | jsonWriter, | ||
| const ExtensionWriterContext & | context ) |
| TExtended | The type with extensions attached to write. This type must have an extensions property of type std::unordered_map<std::string, std::any> or a similar type with an empty() method that returns pairs of <std::string, std::any> when iterated. |
| obj | The object with extensions to write. |
| jsonWriter | The writer to write the extensions object to. |
| context | The ExtensionWriterContext with registered extensions. |
obj have been registered, false otherwise. Definition at line 60 of file writeJsonExtensions.h.
| void CesiumJsonWriter::writeJsonExtensions | ( | const TExtended & | obj, |
| context | The ExtensionWriterContext that provides information on how to write each extension. |
Definition at line 24 of file writeJsonExtensions.h.
| void CesiumJsonWriter::writeJsonValue | ( | const CesiumUtility::JsonValue & | value, |
| JsonWriter & | writer ) |
| value | The value to write. |
| writer | The writer used to write the provided value. |
