cesium-native 0.67.0
Wrapper around rapidjson::Writer for writing objects to JSON.
More...
#include <CesiumJsonWriter/JsonWriter.h>
| virtual bool | Null () |
Writes a null value to the output. | |
| virtual bool | Bool (bool b) |
| Writes a boolean value to the output. | |
| virtual bool | Int (int i) |
| Writes a signed integer value to the output. | |
| virtual bool | Uint (unsigned int i) |
| Writes an unsigned integer value to the output. | |
| virtual bool | Uint64 (std::uint64_t i) |
| Writes an unsigned 64-bit integer value to the output. | |
| virtual bool | Int64 (std::int64_t i) |
| Writes an signed 64-bit integer value to the output. | |
| virtual bool | Double (double d) |
| Writes a 64-bit floating point value to the output. | |
| virtual bool | RawNumber (const char *str, unsigned int length, bool copy) |
| Writes the given string as a number to the output without any kind of special handling. | |
| virtual bool | Key (std::string_view string) |
| Writes the given string as an object key to the output. | |
| virtual bool | String (std::string_view string) |
| Writes the given string as a value to the output. | |
| virtual bool | StartObject () |
| Writes the start of a JSON object to the output. | |
| virtual bool | EndObject () |
| Writes the end of a JSON object to the output. | |
| virtual bool | StartArray () |
| Writes the start of a JSON array to the output. | |
| virtual bool | EndArray () |
| Writes the end of a JSON array to the output. | |
| virtual void | Primitive (std::int32_t value) |
| Writes the given primitive to the output. This is a convenience function for Int. | |
| virtual void | Primitive (std::uint32_t value) |
| Writes the given primitive to the output. This is a convenience function for Uint. | |
| virtual void | Primitive (std::int64_t value) |
| Writes the given primitive to the output. This is a convenience function for Int64. | |
| virtual void | Primitive (std::uint64_t value) |
| Writes the given primitive to the output. This is a convenience function for Uint64. | |
| virtual void | Primitive (float value) |
| Writes the given primitive to the output. This is a convenience function for Double. | |
| virtual void | Primitive (double value) |
| virtual void | Primitive (std::nullptr_t value) |
| Writes the given primitive to the output. This is a convenience function for Null. | |
| virtual void | Primitive (std::string_view string) |
| Writes the given primitive to the output. This is a convenience function for String. | |
| virtual void | KeyPrimitive (std::string_view keyName, std::int32_t value) |
| Writes the given key and its corresponding value primitive to the output. This is a convenience function for calling Key followed by Int. | |
| virtual void | KeyPrimitive (std::string_view keyName, std::uint32_t value) |
| Writes the given key and its corresponding value primitive to the output. This is a convenience function for calling Key followed by Uint. | |
| virtual void | KeyPrimitive (std::string_view keyName, std::int64_t value) |
| Writes the given key and its corresponding value primitive to the output. This is a convenience function for calling Key followed by Int64. | |
| virtual void | KeyPrimitive (std::string_view keyName, std::uint64_t value) |
| Writes the given key and its corresponding value primitive to the output. This is a convenience function for calling Key followed by Uint64. | |
| virtual void | KeyPrimitive (std::string_view keyName, std::string_view value) |
| Writes the given key and its corresponding value primitive to the output. This is a convenience function for calling Key followed by String. | |
| virtual void | KeyPrimitive (std::string_view keyName, float value) |
| Writes the given key and its corresponding value primitive to the output. This is a convenience function for calling Key followed by Double. | |
| virtual void | KeyPrimitive (std::string_view keyName, double value) |
| virtual void | KeyPrimitive (std::string_view keyName, std::nullptr_t value) |
| Writes the given key and its corresponding value primitive to the output. This is a convenience function for calling Key followed by Null. | |
| virtual void | KeyArray (std::string_view keyName, const std::function< void(void)> &insideArray) |
| Writes an array to the output with the given key and calls the provided callback to write values inside of the array. This is a convenience function for calling Key followed by StartArray followed by the values you wish to write and ending with EndArray. | |
| virtual void | KeyObject (std::string_view keyName, const std::function< void(void)> &insideObject) |
| Writes an object to the output with the given key and calls the provided callback to write values inside of the object. This is a convenience function for calling Key followed by StartObject followed by the values you wish to write and ending with EndObject. | |
| virtual std::string | toString () |
| Obtains the written output as a string. | |
| virtual std::string_view | toStringView () |
| Obtains the written output as a string_view. | |
| virtual std::vector< std::byte > | toBytes () |
| Obtains the written output as a buffer of bytes. | |
| template<typename ErrorStr> | |
| void | emplaceError (ErrorStr &&error) |
| Emplaces a new error into the internal error buffer. | |
| template<typename WarningStr> | |
| void | emplaceWarning (WarningStr &&warning) |
| Emplaces a new warning into the internal warning buffer. | |
| const std::vector< std::string > & | getErrors () const |
| Obtains the current error buffer. | |
| const std::vector< std::string > & | getWarnings () const |
| Obtains the current warning buffer. | |
Definition at line 18 of file JsonWriter.h.
virtual |
| b | The boolean value to write. |
Reimplemented in CesiumJsonWriter::PrettyJsonWriter.
virtual |
| d | The double value to write. |
Definition at line 270 of file JsonWriter.h.
Definition at line 277 of file JsonWriter.h.
virtual |
virtual |
Definition at line 284 of file JsonWriter.h.
Definition at line 288 of file JsonWriter.h.
virtual |
| i | The integer value to write. |
virtual |
virtual |
| string | The key to write. |
virtual |
| keyName | The key to write to the output. |
| insideArray | The callback to run, after StartArray but before EndArray. |
virtual |
| insideObject | The callback to run, after StartObject but before EndObject. |
virtual |
| value | The primitive value to write. |
virtual |
virtual |
virtual |
virtual |
virtual |
virtual |
virtual |
virtual |
virtual |
| value | The double value to write. |
virtual |
| value | The float value to write. |
virtual |
| value | The int32_t value to write. |
virtual |
| value | The int64_t value to write. |
virtual |
| value | The null value to write. |
virtual |
| string | The string value to write. |
virtual |
| value | The uint32_t value to write. |
virtual |
| value | The uint64_t value to write. |
virtual |
| str | The raw number to write directly to the output. |
| length | The length of the string. |
| copy | If true, the string will be copied. |
virtual |
virtual |
virtual |
| string | The string to write. |
virtual |
virtual |
virtual |
virtual |
virtual |
