CesiumJsonWriter::ExtensionWriterContext Class Reference
A context for writing extensions where known extensions and their handlers can be registered. More...
#include <CesiumJsonWriter/ExtensionWriterContext.h>
template<typename TExtended, typename TExtensionHandler>
void registerExtension (const std::string &extensionName)
 Registers an extension for an object.
void registerExtension ()
ExtensionState getExtensionState (const std::string &extensionName) const
 Returns whether an extension is enabled or disabled.
void setExtensionState (const std::string &extensionName, ExtensionState newState)
 Enables or disables an extension.
ExtensionHandler< std::any > createExtensionHandler (const std::string_view &extensionName, const std::any &obj, const std::string &extendedObjectType) const
 Attempts to create an ExtensionHandler for the given object, returning nullptr if no handler could be found.
Definition at line 39 of file ExtensionWriterContext.h.
◆ createExtensionHandler()
ExtensionHandler< std::any > CesiumJsonWriter::ExtensionWriterContext::createExtensionHandler ( const std::string_view & extensionName,
const std::any & obj,
const std::string & extendedObjectType ) const
extensionNameThe name of the extension.
objThe object of unknown type to create the handler for.
extendedObjectTypeThe TypeName of the extended object.
The handler for this extension, or nullptr if none could be created.
◆ getExtensionState()
ExtensionState CesiumJsonWriter::ExtensionWriterContext::getExtensionState ( const std::string & extensionName) const
By default, all extensions are enabled.
◆ registerExtension() [1/2]
void CesiumJsonWriter::ExtensionWriterContext::registerExtension ( )
The extension name is obtained from TExtensionHandler::ExtensionName.
Template Parameters
TExtendedThe object to extend.
TExtensionHandlerThe extension's writer.
Definition at line 80 of file ExtensionWriterContext.h.
◆ registerExtension() [2/2]
void CesiumJsonWriter::ExtensionWriterContext::registerExtension ( const std::string & extensionName)
Template Parameters
Definition at line 54 of file ExtensionWriterContext.h.
◆ setExtensionState()
void CesiumJsonWriter::ExtensionWriterContext::setExtensionState ( const std::string & extensionName,
ExtensionState newState )
By default, all extensions are enabled. However, if the extension is a statically-typed class and is not registered it will be ignored and a warning will be reported.
When a disabled extension is encountered, it is ignored completely.
extensionNameThe name of the extension to be enabled or disabled.
newStateThe new state for the extension.
