cesium-native 0.67.0
This guide contains the basic setup information for developers looking to work with Cesium Native. To follow this guide, you will need the following prerequisites:
Check out the repo with:
Cesium Native manages its many dependencies using vcpkg. We use vcpkg's manifest mode, in which vcpkg reads the list of Cesium Native's dependencies and installs them. This requires a local installation of vcpkg and some extra arguments to CMake.
After installing vcpkg – usually by cloning it from https://github.com/microsoft/vcpkg – run the proper bootstrap script and set the VCPKG_ROOT environment variable so that Cesium Native's build can find it:
vcpkg hooks into CMake by loading a toolchain file, which is usually used in cross-compilation scenarios. You can specify this on the command line, but this can become a bit verbose as additional vcpkg options get added, so specifying them all in a CMake presets file is an interesting option. There are example preset files in the cmake-presets directory. We haven't included them in their normal spot in the source tree because they can cause some issues with VS Code, but you can copy CMakeUserPresets.cmake to the root of the Cesium Native source tree to use these predefined presets.
Using presets (on Linux):
By hand:
On Windows:
vcpkg specifies all information about the compilation target in a "triplet". For compiling Cesium Native as a stand-alone, the system defaults will usually work, but consumers of Cesium Native might need something more exotic. For example, one could configure a Windows build with:
1) Install the CMake Tools extension. It should prompt you to generate project files from CMake. 2) On Windows, choose Visual Studio 2017 Release - amd64 as the kit to build. Or choose an appropriate kit for your platform. 3) Then press Ctrl-Shift-P and execute the CMake: Build task or press F7.
1) Open the CMake UI (cmake-gui) 2) Under "Where is the source code", point to your repo 3) Specify your output folder in "Where to build the binaries" 4) Click "Configure". 5) Under "Specify the generator for this project", choose the VS version on your system 6) Click Finish, wait for the process to finish 7) Click Generate
Look for cesium-native.sln in your output folder.
Unit tests can also be run from this solution, under the cesium-native-tests project.
npm installcmake --build build --target cesium-native-docsbuild/doc/html/index.htmlMuch of the code in CesiumGltf, CesiumTilesetJson, CesiumGltfReader, CesiumGltfWriter, CesiumTilesetJsonReader, CesiumTilesetJsonWriter, and CesiumQuantizedMeshTerrain is generated from the standards' JSON Schema specifications. To regenerate the code:
npm run generate-gltfnpm run generate-3d-tilesnpm run generate-quantized-mesh-terraingit add them and git will fix the line endings (no need to commit).The dependency graphs used in the Cesium Native documentation are generated using a script that parses CMake's GraphViz output and generates a set of Mermaid diagrams. To regenerate the graphs:
tools/dep-graph-gen directory, run npm run generate-dep-graph to regenerate the graphs.We use clang-tidy to help improve the quality of the code, and an automated process that runs on every commit ensures that there are no clang-tidy warnings or errors. To run it locally, follow the instructions for your system.
It's recommended to use WSL2 to run clang-tidy on Windows. The following instructions cover using clang-tidy through Visual Studio 2022's CMake support. To set up clang-tidy on WSL2, follow the Linux instructions below.
LLVM-19.x.x-win64.exe and run the installer.compile_commands.json file to be generated in the build directory in order to run. This file is only generated with the cmake Ninja or Unix Makefile generators. Visual Studio 2022's CMake support uses the Ninja generator. Open the Cesium Native cmake project with Visual Studio 2022.CMakeLists.txt and select "CMake Settings for cesium-native"
clang-tidy.exe under "CMake command arguments":
CESIUM_ENABLE_CLANG_TIDY_ON_BUILD:
Binaries and source releases for use with other platforms can be downloaded from the LLVM GitHub releases page.
clang-tidy-19 automatically, so the project can be configured normally:sed to extract the errors and warnings from the log:sed to extract the errors and warnings from the log:
