CesiumTilesetJsonReader::SubtreeFileReader Class Reference
Reads 3D Tiles subtrees from a binary or JSON subtree file. More...
#include <CesiumTilesetJsonReader/SubtreeFileReader.h>
 SubtreeFileReader ()
CesiumAsync::Future< CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Subtree > > load (const CesiumAsync::AsyncSystem &asyncSystem, const std::shared_ptr< CesiumAsync::IAssetAccessor > &pAssetAccessor, const std::string &url, const std::vector< CesiumAsync::IAssetAccessor::THeader > &headers={}) const noexcept
 Asynchronously loads a subtree from a URL.
CesiumAsync::Future< CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Subtree > > load (const CesiumAsync::AsyncSystem &asyncSystem, const std::shared_ptr< CesiumAsync::IAssetAccessor > &pAssetAccessor, const std::shared_ptr< CesiumAsync::IAssetRequest > &pRequest) const noexcept
 Asynchronously loads a subtree from a request.
CesiumAsync::Future< CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Subtree > > load (const CesiumAsync::AsyncSystem &asyncSystem, const std::shared_ptr< CesiumAsync::IAssetAccessor > &pAssetAccessor, const std::string &url, const std::vector< CesiumAsync::IAssetAccessor::THeader > &requestHeaders, const std::span< const std::byte > &data) const noexcept
 Asynchronously loads a subtree from data obtained from a URL.
CesiumAsync::Future< CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Subtree > > load (const CesiumAsync::AsyncSystem &asyncSystem, const std::shared_ptr< CesiumAsync::IAssetAccessor > &pAssetAccessor, const std::string &url, const std::vector< CesiumAsync::IAssetAccessor::THeader > &requestHeaders, const rapidjson::Document &document) const noexcept
 Asynchronously loads a subtree from a rapidjson::Document obtained from a URL.
While SubtreeReader can parse a CesiumTilesetJson::Subtree from a binary buffer as well, SubtreeFileReader additionally supports:
  1. Loading binary subtree files.
  2. Loading external buffers asynchronously.
  3. Decoding buffers from data URIs.
The subtree file need not be an actual file on disk.
Definition at line 25 of file SubtreeFileReader.h.
◆ load() [1/4]
CesiumAsync::Future< CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Subtree > > CesiumTilesetJsonReader::SubtreeFileReader::load ( const CesiumAsync::AsyncSystem & asyncSystem,
const std::shared_ptr< CesiumAsync::IAssetAccessor > & pAssetAccessor,
const std::shared_ptr< CesiumAsync::IAssetRequest > & pRequest ) const
noexcept
Attention
Please note that the SubtreeFileReader instance must remain valid until the returned future resolves or rejects. Destroying it earlier will result in undefined behavior. One easy way to achieve this is to construct the reader with std::make_shared and capture the std::shared_ptr in the continuation lambda.
asyncSystemThe AsyncSystem used to do asynchronous work.
pAssetAccessorThe accessor used to retrieve the URL and any other required resources.
pRequestThe request to get the subtree file.
A future that resolves to the result of loading the subtree.
◆ load() [2/4]
const std::string & url,
const std::vector< CesiumAsync::IAssetAccessor::THeader > & headers = {} ) const
noexcept
Attention
urlThe URL from which to get the subtree file.
headersHeaders to include in the request for the initial subtree file and any additional resources that are required.
◆ load() [3/4]
const std::vector< CesiumAsync::IAssetAccessor::THeader > & requestHeaders,
const rapidjson::Document & document ) const
noexcept
Attention
urlThe URL from which the subtree file was obtained.
requestHeadersHeaders that were included in the request for the initial subtree file and should be included for any additional resources that are required.
documentThe JSON document that was obtained.
◆ load() [4/4]
const std::span< const std::byte > & data ) const
noexcept
Attention
dataThe subtree file data that was obtained.
