CesiumGltf::PropertyArrayCopy< std::string_view > Class Reference
A copy of a string array element of a PropertyTableProperty. More...
#include <CesiumGltf/PropertyArrayView.h>
 PropertyArrayCopy ()
 Constructs an empty array copy.
 PropertyArrayCopy (const std::vector< std::string > &values) noexcept
 Constructs a string array copy from a vector.
 PropertyArrayCopy (PropertyArrayCopy &&)=default
 Default move constructor.
PropertyArrayCopy & operator= (PropertyArrayCopy &&)=default
 Default move assignment operator.
 PropertyArrayCopy (const PropertyArrayCopy &rhs)
 Copy constructor.
PropertyArrayCopy & operator= (const PropertyArrayCopy &rhs)
 Copy assignment operator.
std::string_view operator[] (int64_t index) const noexcept
 Returns the ElementType at the given index from this copy.
int64_t size () const noexcept
 The number of elements in this array.
const PropertyArrayView< std::string_view > & view () const
 Obtains a PropertyArrayView over the contents of this copy.
PropertyArrayView< std::string_view > toViewAndExternalBuffer (std::vector< std::byte > &outBuffer) &&
 Obtains a buffer and view from the copied data, leaving this PropertyArrayCopy empty.
 PropertyArrayCopy (const std::vector< std::string_view > &values) noexcept
 Constructs an array copy from a vector.
 PropertyArrayCopy (std::vector< std::byte > &&buffer) noexcept
 Creates a new PropertyArrayCopy directly from a buffer of bytes, which will be moved into this copy.
 Copy constructor.
const std::string_view & operator[] (int64_t index) const noexcept
auto begin ()
 The begin iterator.
auto begin () const
 The begin iterator.
auto end ()
 The end iterator.
auto end () const
 The end iterator.
Whereas PropertyArrayView is a pointer to data stored in a separate place, a PropertyArrayCopy owns the data that it's viewing.
Provides utility to retrieve the data stored in the array of elements via the array index operator.
Definition at line 395 of file PropertyArrayView.h.
◆ PropertyArrayCopy() [1/7]
CesiumGltf::PropertyArrayCopy< std::string_view >::PropertyArrayCopy ( )
Definition at line 400 of file PropertyArrayView.h.
◆ PropertyArrayCopy() [2/7]
CesiumGltf::PropertyArrayCopy< std::string_view >::PropertyArrayCopy ( const std::vector< std::string > & values)
inlinenoexcept
valuesThe vector containing the values.
Definition at line 407 of file PropertyArrayView.h.
◆ PropertyArrayCopy() [3/7]
CesiumGltf::PropertyArrayCopy< std::string_view >::PropertyArrayCopy ( const PropertyArrayCopy< std::string_view > & rhs)
Copy constructor.
Definition at line 475 of file PropertyArrayView.h.
◆ PropertyArrayCopy() [4/7]
Definition at line 82 of file PropertyArrayView.h.
◆ PropertyArrayCopy() [5/7]
CesiumGltf::PropertyArrayCopy< std::string_view >::PropertyArrayCopy ( const std::vector< std::string_view > & values)
inlinenoexcept
Definition at line 89 of file PropertyArrayView.h.
◆ PropertyArrayCopy() [6/7]
CesiumGltf::PropertyArrayCopy< std::string_view >::PropertyArrayCopy ( std::vector< std::byte > && buffer)
inlinenoexcept
Definition at line 109 of file PropertyArrayView.h.
◆ PropertyArrayCopy() [7/7]
Copy constructor.
Definition at line 113 of file PropertyArrayView.h.
◆ begin() [1/2]
auto CesiumGltf::PropertyArrayCopy< std::string_view >::begin ( )
The begin iterator.
Definition at line 137 of file PropertyArrayView.h.
◆ begin() [2/2]
auto CesiumGltf::PropertyArrayCopy< std::string_view >::begin ( ) const
The begin iterator.
Definition at line 141 of file PropertyArrayView.h.
◆ end() [1/2]
auto CesiumGltf::PropertyArrayCopy< std::string_view >::end ( )
The end iterator.
Definition at line 139 of file PropertyArrayView.h.
◆ end() [2/2]
auto CesiumGltf::PropertyArrayCopy< std::string_view >::end ( ) const
The end iterator.
Definition at line 143 of file PropertyArrayView.h.
◆ operator=() [1/2]
PropertyArrayCopy & CesiumGltf::PropertyArrayCopy< std::string_view >::operator= ( const PropertyArrayCopy< std::string_view > & rhs)
Definition at line 117 of file PropertyArrayView.h.
◆ operator=() [2/2]
Definition at line 490 of file PropertyArrayView.h.
◆ operator[]() [1/2]
const std::string_view & CesiumGltf::PropertyArrayCopy< std::string_view >::operator[] ( int64_t index) const
inlinenoexcept
indexThe index to obtain.
The ElementType at that index from the internal view.
Definition at line 129 of file PropertyArrayView.h.
◆ operator[]() [2/2]
std::string_view CesiumGltf::PropertyArrayCopy< std::string_view >::operator[] ( int64_t index) const
inlinenoexcept
Definition at line 511 of file PropertyArrayView.h.
◆ size() [1/2]
int64_t CesiumGltf::PropertyArrayCopy< std::string_view >::size ( ) const
inlinenoexcept
Definition at line 134 of file PropertyArrayView.h.
◆ size() [2/2]
inlinenoexcept
Definition at line 516 of file PropertyArrayView.h.
◆ toViewAndExternalBuffer() [1/2]
PropertyArrayView< std::string_view > CesiumGltf::PropertyArrayCopy< std::string_view >::toViewAndExternalBuffer ( std::vector< std::byte > & outBuffer) &&
outBufferThe destination where this copy's internal buffer will be moved to.
Definition at line 158 of file PropertyArrayView.h.
◆ toViewAndExternalBuffer() [2/2]
Definition at line 533 of file PropertyArrayView.h.
◆ view() [1/2]
const PropertyArrayView< std::string_view > & CesiumGltf::PropertyArrayCopy< std::string_view >::view ( ) const
Definition at line 148 of file PropertyArrayView.h.
◆ view() [2/2]
Definition at line 521 of file PropertyArrayView.h.
