CesiumGltfWriter::GltfWriter Class Reference
Writes glTF. More...
#include <CesiumGltfWriter/GltfWriter.h>
 GltfWriter ()
CesiumJsonWriter::ExtensionWriterContext & getExtensions ()
 Gets the context used to control how glTF extensions are written.
const CesiumJsonWriter::ExtensionWriterContext & getExtensions () const
GltfWriterResult writeGltf (const CesiumGltf::Model &model, const GltfWriterOptions &options=GltfWriterOptions()) const
 Serializes the provided model into a glTF JSON byte vector.
GltfWriterResult writeGlb (const CesiumGltf::Model &model, const std::span< const std::byte > &bufferData, const GltfWriterOptions &options=GltfWriterOptions()) const
 Serializes the provided model into a glb byte vector.
Writes glTF.
Definition at line 56 of file GltfWriter.h.
◆ writeGlb()
GltfWriterResult CesiumGltfWriter::GltfWriter::writeGlb ( const CesiumGltf::Model & model,
const std::span< const std::byte > & bufferData,
const GltfWriterOptions & options = GltfWriterOptions() ) const
The first buffer object implicitly refers to the GLB binary chunk and should not have a uri. Ignores internal data such as CesiumGltf::BufferCesium and CesiumImage::ImageAsset .
modelThe model.
bufferDataThe buffer data to store in the GLB binary chunk.
optionsOptions for how to write the glb.
The result of writing the glb.
◆ writeGltf()
GltfWriterResult CesiumGltfWriter::GltfWriter::writeGltf ( const CesiumGltf::Model & model,
Ignores internal data such as CesiumGltf::BufferCesium and CesiumImage::ImageAsset when serializing the glTF. Internal data must either be converted to data uris or saved as external files. The buffer.uri and image.uri fields must be set accordingly prior to calling this function.
modelThe model.
optionsOptions for how to write the glTF.
The result of writing the glTF.
