CesiumAsync::CachingAssetAccessor Class Reference
A decorator for an IAssetAccessor that caches requests and responses in an ICacheDatabase. More...
#include <CesiumAsync/CachingAssetAccessor.h>
Inheritance diagram for CesiumAsync::CachingAssetAccessor:
CesiumAsync::IAssetAccessor
 CachingAssetAccessor (const std::shared_ptr< spdlog::logger > &pLogger, const std::shared_ptr< IAssetAccessor > &pAssetAccessor, const std::shared_ptr< ICacheDatabase > &pCacheDatabase, int32_t requestsPerCachePrune=10000)
virtual Future< std::shared_ptr< IAssetRequest > > get (const AsyncSystem &asyncSystem, const std::string &url, const std::vector< THeader > &headers) override
 Starts a new request for the asset with the given URL. The request proceeds asynchronously without blocking the calling thread.
virtual Future< std::shared_ptr< IAssetRequest > > request (const AsyncSystem &asyncSystem, const std::string &verb, const std::string &url, const std::vector< THeader > &headers, const std::span< const std::byte > &contentPayload) override
 Starts a new request to the given URL, using the provided HTTP verb and the provided content payload.
virtual void tick () noexcept override
 Ticks the asset accessor system while the main thread is blocked.
Additional Inherited Members
- Public Types inherited from CesiumAsync::IAssetAccessor
typedef std::pair< std::string, std::string > THeader
 An HTTP header represented as a key/value pair.
This can be used to improve asset loading performance by caching assets across runs.
Definition at line 25 of file CachingAssetAccessor.h.
◆ CachingAssetAccessor()
CesiumAsync::CachingAssetAccessor::CachingAssetAccessor ( const std::shared_ptr< spdlog::logger > & pLogger,
const std::shared_ptr< IAssetAccessor > & pAssetAccessor,
const std::shared_ptr< ICacheDatabase > & pCacheDatabase,
int32_t requestsPerCachePrune = 10000 )
pLoggerThe logger that receives messages about the status of this instance.
pAssetAccessorThe underlying IAssetAccessor used to retrieve assets that are not in the cache.
pCacheDatabaseThe database in which to cache requests and responses.
requestsPerCachePruneThe number of requests to handle before each ICacheDatabase::prune of old cached results from the database.
◆ get()
virtual Future< std::shared_ptr< IAssetRequest > > CesiumAsync::CachingAssetAccessor::get ( const AsyncSystem & asyncSystem,
const std::string & url,
const std::vector< THeader > & headers )
overridevirtual
asyncSystemThe async system used to do work in threads.
urlThe URL of the asset.
headersThe headers to include in the request.
The in-progress asset request.
Implements CesiumAsync::IAssetAccessor.
◆ request()
virtual Future< std::shared_ptr< IAssetRequest > > CesiumAsync::CachingAssetAccessor::request ( const AsyncSystem & asyncSystem,
const std::string & verb,
const std::vector< THeader > & headers,
const std::span< const std::byte > & contentPayload )
overridevirtual
verbThe HTTP verb to use, such as "POST" or "PATCH".
contentPayloadThe payload data to include in the request.
◆ tick()
virtual void CesiumAsync::CachingAssetAccessor::tick ( )
overridevirtualnoexcept
If the asset accessor is not dependent on the main thread to dispatch requests, this method does not need to do anything.
