CesiumCurl::CurlAssetAccessor Class Reference
An implementation of IAssetAccessor that can make network and local requests to a variety of servers using libcurl. More...
#include <CesiumCurl/CurlAssetAccessor.h>
Inheritance diagram for CesiumCurl::CurlAssetAccessor:
CesiumAsync::IAssetAccessor
 CurlAssetAccessor (const CurlAssetAccessorOptions &options={})
const CurlAssetAccessorOptions & getOptions () const
 Gets the options that were used to construct this accessor.
CesiumAsync::Future< std::shared_ptr< CesiumAsync::IAssetRequest > > get (const CesiumAsync::AsyncSystem &asyncSystem, const std::string &url, const std::vector< CesiumAsync::IAssetAccessor::THeader > &headers) override
CesiumAsync::Future< std::shared_ptr< CesiumAsync::IAssetRequest > > request (const CesiumAsync::AsyncSystem &asyncSystem, const std::string &verb, const std::string &url, const std::vector< CesiumAsync::IAssetAccessor::THeader > &headers, const std::span< const std::byte > &contentPayload) override
void tick () noexcept override
Additional Inherited Members
- Public Types inherited from CesiumAsync::IAssetAccessor
typedef std::pair< std::string, std::string > THeader
 An HTTP header represented as a key/value pair.
Definition at line 89 of file CurlAssetAccessor.h.
◆ CurlAssetAccessor()
CesiumCurl::CurlAssetAccessor::CurlAssetAccessor ( const CurlAssetAccessorOptions & options = {})
optionsThe options with which to construct this instance.
◆ get()
CesiumAsync::Future< std::shared_ptr< CesiumAsync::IAssetRequest > > CesiumCurl::CurlAssetAccessor::get ( const CesiumAsync::AsyncSystem & asyncSystem,
const std::string & url,
const std::vector< CesiumAsync::IAssetAccessor::THeader > & headers )
overridevirtual
Starts a new request for the asset with the given URL. The request proceeds asynchronously without blocking the calling thread.
asyncSystemThe async system used to do work in threads.
urlThe URL of the asset.
headersThe headers to include in the request.
The in-progress asset request.
Implements CesiumAsync::IAssetAccessor.
◆ request()
CesiumAsync::Future< std::shared_ptr< CesiumAsync::IAssetRequest > > CesiumCurl::CurlAssetAccessor::request ( const CesiumAsync::AsyncSystem & asyncSystem,
const std::string & verb,
const std::vector< CesiumAsync::IAssetAccessor::THeader > & headers,
const std::span< const std::byte > & contentPayload )
overridevirtual
Starts a new request to the given URL, using the provided HTTP verb and the provided content payload.The request proceeds asynchronously without blocking the calling thread.
verbThe HTTP verb to use, such as "POST" or "PATCH".
contentPayloadThe payload data to include in the request.
◆ tick()
void CesiumCurl::CurlAssetAccessor::tick ( )
overridevirtualnoexcept
Ticks the asset accessor system while the main thread is blocked.If the asset accessor is not dependent on the main thread to dispatch requests, this method does not need to do anything.
