Cesium3DTilesWriter::SubtreeWriter Class Reference
Writes subtrees. More...
#include <Cesium3DTilesWriter/SubtreeWriter.h>
 SubtreeWriter ()
CesiumJsonWriter::ExtensionWriterContext & getExtensions ()
 Gets the context used to control how subtree extensions are written.
const CesiumJsonWriter::ExtensionWriterContext & getExtensions () const
SubtreeWriterResult writeSubtreeJson (const Cesium3DTiles::Subtree &subtree, const SubtreeWriterOptions &options=SubtreeWriterOptions()) const
 Serializes the provided subtree into a subtree JSON byte vector.
SubtreeWriterResult writeSubtreeBinary (const Cesium3DTiles::Subtree &subtree, const std::span< const std::byte > &bufferData, const SubtreeWriterOptions &options=SubtreeWriterOptions()) const
 Serializes the provided subtree into a subtree binary byte vector.
Writes subtrees.
Definition at line 52 of file SubtreeWriter.h.
◆ writeSubtreeBinary()
SubtreeWriterResult Cesium3DTilesWriter::SubtreeWriter::writeSubtreeBinary ( const Cesium3DTiles::Subtree & subtree,
const std::span< const std::byte > & bufferData,
const SubtreeWriterOptions & options = SubtreeWriterOptions() ) const
The first buffer object implicitly refers to the subtree binary section and should not have a uri. Ignores internal data such as Cesium3DTiles::BufferCesium.
subtreeThe subtree.
bufferDataThe buffer data to store in the subtree binary section.
optionsOptions for how to write the subtree.
The result of writing the subtree.
◆ writeSubtreeJson()
SubtreeWriterResult Cesium3DTilesWriter::SubtreeWriter::writeSubtreeJson ( const Cesium3DTiles::Subtree & subtree,
Ignores internal data such as Cesium3DTiles::BufferCesium when serializing the subtree. Internal data must be saved as external files. The buffer.uri field must be set accordingly prior to calling this function.
subtreeThe subtree.
