cesium-native 0.67.0
An iterator over constant Tile instances. More...
#include <Cesium3DTilesSelection/LoadedTileEnumerator.h>
Public Types | |
| using | iterator_category = std::forward_iterator_tag |
| The iterator category tag denoting this is a forward iterator. | |
| using | value_type = const Tile |
| The type of value that is being iterated over. | |
| using | difference_type = void |
| The type used to identify distance between iterators. | |
| using | pointer = const Tile* |
| A pointer to the type being iterated over. | |
| using | reference = const Tile& |
| A reference to the type being iterated over. | |
| const Tile & | operator* () const noexcept |
| Returns a reference to the current item being iterated. | |
| const Tile * | operator-> () const noexcept |
| Returns a pointer to the current item being iterated. | |
| const_iterator & | operator++ () noexcept |
| Advances the iterator to the next item (pre-incrementing). | |
| const_iterator | operator++ (int) noexcept |
| Advances the iterator to the next item (post-incrementing). | |
| bool | operator== (const const_iterator &rhs) const noexcept |
| Checks if two iterators are at the same item. | |
| bool | operator!= (const const_iterator &rhs) const noexcept |
| Checks if two iterators are not at the same item. | |
Friends | |
| class | LoadedTileEnumerator |
| class | LoadedConstTileEnumerator |
Definition at line 30 of file LoadedTileEnumerator.h.
This is void because there is no meaningful measure of distance between tiles.
Definition at line 46 of file LoadedTileEnumerator.h.
| using Cesium3DTilesSelection::LoadedConstTileEnumerator::const_iterator::iterator_category = std::forward_iterator_tag |
Definition at line 35 of file LoadedTileEnumerator.h.
Definition at line 50 of file LoadedTileEnumerator.h.
Definition at line 54 of file LoadedTileEnumerator.h.
Definition at line 39 of file LoadedTileEnumerator.h.
friend |
Definition at line 85 of file LoadedTileEnumerator.h.
friend |
Definition at line 84 of file LoadedTileEnumerator.h.
