MeshReader.h
5#include <CesiumGltf/Mesh.h>
9
10#include <rapidjson/fwd.h>
11
12#include <span>
13#include <vector>
14
15namespace CesiumGltf {
16struct Mesh;
17} // namespace CesiumGltf
18
20
24class CESIUMGLTFREADER_API MeshReader {
25public:
30
35
40
48 readFromJson(const std::span<const std::byte>& data) const;
49
57 readFromJson(const rapidjson::Value& value) const;
58
66 readArrayFromJson(const rapidjson::Value& value) const;
67
68private:
70};
71
MeshReader()
CesiumJsonReader::ReadJsonResult< CesiumGltf::Mesh > readFromJson(const rapidjson::Value &value) const
Reads an instance of Mesh from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Mesh > > readArrayFromJson(const rapidjson::Value &value) const
Reads an array of instances of Mesh from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< CesiumGltf::Mesh > readFromJson(const std::span< const std::byte > &data) const
Reads an instance of Mesh from a byte buffer.
Definition GltfReader.h:23
A set of primitives to be rendered. Its global transform is defined by a node that references it.
Definition Mesh.h:16
Definition JsonReader.h:23
