ExtensionSchemaMaxarContentGeoJson Geometry Value. More...
#include <Cesium3DTiles/ExtensionSchemaMaxarContentGeoJsonGeometryValue.h>
Classes | |
| struct | Type |
| Known values for Type of GeoJSON geometry inside the group. More... | |
| std::string | type = Type::Point |
| Type of GeoJSON geometry inside the group. | |
| int64_t | dimensions = int64_t() |
| 2D or 3D geometries | |
Definition at line 15 of file ExtensionSchemaMaxarContentGeoJsonGeometryValue.h.
Definition at line 65 of file ExtensionSchemaMaxarContentGeoJsonGeometryValue.h.
| int64_t Cesium3DTiles::ExtensionSchemaMaxarContentGeoJsonGeometryValue::dimensions = int64_t() |
2D or 3D geometries
Definition at line 57 of file ExtensionSchemaMaxarContentGeoJsonGeometryValue.h.
| std::string Cesium3DTiles::ExtensionSchemaMaxarContentGeoJsonGeometryValue::type = Type::Point |
Definition at line 52 of file ExtensionSchemaMaxarContentGeoJsonGeometryValue.h.
Definition at line 20 of file ExtensionSchemaMaxarContentGeoJsonGeometryValue.h.
