Extension3dTilesSubtreeReader.h
5#include <CesiumGltf/Extension3dTilesSubtree.h>
9
10#include <rapidjson/fwd.h>
11
12#include <span>
13#include <vector>
14
15namespace CesiumGltf {
17} // namespace CesiumGltf
18
20
25class CESIUMGLTFREADER_API Extension3dTilesSubtreeReader {
26public:
31
36
41
49 readFromJson(const std::span<const std::byte>& data) const;
50
59 readFromJson(const rapidjson::Value& value) const;
60
69 std::vector<CesiumGltf::Extension3dTilesSubtree>>
70 readArrayFromJson(const rapidjson::Value& value) const;
71
72private:
74};
75
76} // namespace CesiumGltfReader
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Extension3dTilesSubtree > > readArrayFromJson(const rapidjson::Value &value) const
Reads an array of instances of Extension3dTilesSubtree from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< CesiumGltf::Extension3dTilesSubtree > readFromJson(const rapidjson::Value &value) const
Reads an instance of Extension3dTilesSubtree from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< CesiumGltf::Extension3dTilesSubtree > readFromJson(const std::span< const std::byte > &data) const
Reads an instance of Extension3dTilesSubtree from a byte buffer.
Extension3dTilesSubtreeReader()
Definition GltfReader.h:23
An object describing tile, content, and child subtree availability, attributes, and properties.
Definition JsonReader.h:23
