CesiumGltfReader::Extension3dTilesSubtreeReader Class Reference
Reads Extension3dTilesSubtree instances from JSON. More...
#include <CesiumGltfReader/Extension3dTilesSubtreeReader.h>
 Extension3dTilesSubtreeReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::Extension3dTilesSubtree > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of Extension3dTilesSubtree from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::Extension3dTilesSubtree > readFromJson (const rapidjson::Value &value) const
 Reads an instance of Extension3dTilesSubtree from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Extension3dTilesSubtree > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of Extension3dTilesSubtree from a rapidJson::Value.
Definition at line 25 of file Extension3dTilesSubtreeReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Extension3dTilesSubtree > > CesiumGltfReader::Extension3dTilesSubtreeReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Extension3dTilesSubtree > CesiumGltfReader::Extension3dTilesSubtreeReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Extension3dTilesSubtree > CesiumGltfReader::Extension3dTilesSubtreeReader::readFromJson ( const std::span< const std::byte > & data) const
