CylinderReader.h
5#include <CesiumGltf/Cylinder.h>
9
10#include <rapidjson/fwd.h>
11
12#include <span>
13#include <vector>
14
15namespace CesiumGltf {
16struct Cylinder;
17} // namespace CesiumGltf
18
20
71
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Cylinder > > readArrayFromJson(const rapidjson::Value &value) const
Reads an array of instances of Cylinder from a rapidJson::Value.
CylinderReader()
CesiumJsonReader::ReadJsonResult< CesiumGltf::Cylinder > readFromJson(const rapidjson::Value &value) const
Reads an instance of Cylinder from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< CesiumGltf::Cylinder > readFromJson(const std::span< const std::byte > &data) const
Reads an instance of Cylinder from a byte buffer.
Definition GltfReader.h:23
A cylinder, centered at the origin in local space with potentially different radii at each end,...
Definition Cylinder.h:16
Definition JsonReader.h:23
