SchemaWriter.h
3#include <Cesium3DTilesWriter/Library.h>
4#include <CesiumJsonWriter/ExtensionWriterContext.h>
5
6// forward declarations
7namespace Cesium3DTiles {
8struct Schema;
9}
10
11namespace Cesium3DTilesWriter {
12
17struct CESIUM3DTILESWRITER_API SchemaWriterResult {
21 std::vector<std::byte> schemaBytes;
22
26 std::vector<std::string> errors;
27
31 std::vector<std::string> warnings;
32};
33
37struct CESIUM3DTILESWRITER_API SchemaWriterOptions {
41 bool prettyPrint = false;
42};
43
79
80} // namespace Cesium3DTilesWriter
const CesiumJsonWriter::ExtensionWriterContext & getExtensions() const
Gets the context used to control how schema extensions are written.
SchemaWriter()
SchemaWriterResult writeSchema(const Cesium3DTiles::Schema &schema, const SchemaWriterOptions &options=SchemaWriterOptions()) const
Serializes the provided schema object into a byte vector using the provided flags to convert.
Classes for writing 3D Tiles.
Classes for using 3D Tiles.
Definition Buffer.h:7
Options for how to write a schema.
bool prettyPrint
If the schema JSON should be pretty printed.
The result of writing a schema with SchemaWriter::writeSchema.
std::vector< std::byte > schemaBytes
The final generated std::vector<std::byte> of the schema JSON.
Definition Schema.h:18
