AttributeCompression.h
3#include <CesiumUtility/Library.h>
4#include <CesiumUtility/Math.h>
5
6#include <glm/glm.hpp>
8namespace CesiumUtility {
12class CESIUMUTILITY_API AttributeCompression final {
13
14public:
25 template <
26 typename T,
27 class = typename std::enable_if<std::is_unsigned<T>::value>::type>
28 static glm::dvec3 octDecodeInRange(T x, T y, T rangeMax) {
29 glm::dvec3 result;
30
31 result.x = CesiumUtility::Math::fromSNorm(x, rangeMax);
32 result.y = CesiumUtility::Math::fromSNorm(y, rangeMax);
33 result.z = 1.0 - (glm::abs(result.x) + glm::abs(result.y));
34
35 if (result.z < 0.0) {
36 const double oldVX = result.x;
37 result.x =
38 (1.0 - glm::abs(result.y)) * CesiumUtility::Math::signNotZero(oldVX);
39 result.y =
40 (1.0 - glm::abs(oldVX)) * CesiumUtility::Math::signNotZero(result.y);
41 }
42
43 return glm::normalize(result);
44 }
45
56 static glm::dvec3 octDecode(uint8_t x, uint8_t y) {
57 constexpr uint8_t rangeMax = 255;
58 return AttributeCompression::octDecodeInRange(x, y, rangeMax);
59 }
60
68 static glm::dvec3 decodeRGB565(const uint16_t value) {
69 constexpr uint16_t mask5 = (1 << 5) - 1;
70 constexpr uint16_t mask6 = (1 << 6) - 1;
71 constexpr float normalize5 = 1.0f / 31.0f; // normalize [0, 31] to [0, 1]
72 constexpr float normalize6 = 1.0f / 63.0f; // normalize [0, 63] to [0, 1]
73
74 const uint16_t red = static_cast<uint16_t>(value >> 11);
75 const uint16_t green = static_cast<uint16_t>((value >> 5) & mask6);
76 const uint16_t blue = value & mask5;
77
78 return glm::dvec3(red * normalize5, green * normalize6, blue * normalize5);
79 };
80};
81
82} // namespace CesiumUtility
Functions to handle compressed attributes in different formats.
Decodes a unit-length vector in 2 byte 'oct' encoding to a normalized 3-component vector.
Decodes a RGB565-encoded color to a 3-component vector containing the normalized RGB values.
Decodes a unit-length vector in 'oct' encoding to a normalized 3-component vector.
static constexpr double signNotZero(double value) noexcept
Returns 1.0 if the given value is positive or zero, and -1.0 if it is negative.
Definition Math.h:305
static constexpr double fromSNorm(double value, double rangeMaximum=255.0) noexcept
Converts a SNORM value in the range [0, rangeMaximum] to a scalar in the range [-1....
Definition Math.h:432
Utility classes for Cesium.
