UDEPRECATED_CesiumEncodedMetadataComponent Class Reference
An actor component that can be added to Cesium3DTileset actors to dictate what metadata to encode for access on the GPU. More...
#include <CesiumEncodedMetadataComponent.h>
Inheritance diagram for UDEPRECATED_CesiumEncodedMetadataComponent:
TArray< FFeatureTableDescription > FeatureTables
 Descriptions of feature tables to upload to the GPU.
TArray< FFeatureTextureDescription > FeatureTextures
 Descriptions of feature textures to upload to the GPU.
The selection can be automatically populated based on available metadata by clicking the "Auto Fill" button. Once a selection of desired metadata is made, the boiler-plate material code to access the selected properties can be auto-generated using the "Generate Material" button.
Deprecated
Use UCesiumFeaturesMetadataComponent instead.
Definition at line 268 of file CesiumEncodedMetadataComponent.h.
◆ FeatureTables
TArray<FFeatureTableDescription> UDEPRECATED_CesiumEncodedMetadataComponent::FeatureTables
Definition at line 306 of file CesiumEncodedMetadataComponent.h.
◆ FeatureTextures
TArray<FFeatureTextureDescription> UDEPRECATED_CesiumEncodedMetadataComponent::FeatureTextures
Definition at line 319 of file CesiumEncodedMetadataComponent.h.
