UCesiumPropertyTablePropertyBlueprintLibrary Class Reference
#include <CesiumPropertyTableProperty.h>
Inheritance diagram for UCesiumPropertyTablePropertyBlueprintLibrary:
static ECesiumPropertyTablePropertyStatus GetPropertyTablePropertyStatus (UPARAM(ref) const FCesiumPropertyTableProperty &Property)
 Gets the status of the property table property.
static ECesiumMetadataBlueprintType GetBlueprintType (UPARAM(ref) const FCesiumPropertyTableProperty &Property)
 Gets the best-fitting type for the property that is accessible from Blueprints.
static ECesiumMetadataBlueprintType GetArrayElementBlueprintType (UPARAM(ref) const FCesiumPropertyTableProperty &Property)
 Gets the best-fitting Blueprints type for the elements in this property's array values.
static PRAGMA_DISABLE_DEPRECATION_WARNINGS ECesiumMetadataBlueprintType GetBlueprintComponentType (UPARAM(ref) const FCesiumPropertyTableProperty &Property)
static PRAGMA_ENABLE_DEPRECATION_WARNINGS FCesiumMetadataValueType GetValueType (UPARAM(ref) const FCesiumPropertyTableProperty &Property)
 Gets the type of the metadata value as defined in the EXT_structural_metadata extension.
static PRAGMA_DISABLE_DEPRECATION_WARNINGS ECesiumMetadataTrueType_DEPRECATED GetTrueType (UPARAM(ref) const FCesiumPropertyTableProperty &Value)
 Gets true type of the value.
static ECesiumMetadataTrueType_DEPRECATED GetTrueComponentType (UPARAM(ref) const FCesiumPropertyTableProperty &Value)
 Gets true type of the elements in this array property.
static PRAGMA_ENABLE_DEPRECATION_WARNINGS int64 GetPropertySize (UPARAM(ref) const FCesiumPropertyTableProperty &Property)
 Gets the number of values in the property.
static PRAGMA_DISABLE_DEPRECATION_WARNINGS int64 GetNumberOfFeatures (UPARAM(ref) const FCesiumPropertyTableProperty &Property)
 Gets the number of values in this property.
static PRAGMA_ENABLE_DEPRECATION_WARNINGS int64 GetArraySize (UPARAM(ref) const FCesiumPropertyTableProperty &Property)
 Gets the number of elements in an array of this property.
static PRAGMA_DISABLE_DEPRECATION_WARNINGS int64 GetComponentCount (UPARAM(ref) const FCesiumPropertyTableProperty &Property)
static PRAGMA_ENABLE_DEPRECATION_WARNINGS bool GetBoolean (UPARAM(ref) const FCesiumPropertyTableProperty &Property, int64 FeatureID, bool DefaultValue=false)
 Attempts to retrieve the value for the given feature as a boolean.
static uint8 GetByte (UPARAM(ref) const FCesiumPropertyTableProperty &Property, int64 FeatureID, uint8 DefaultValue=0)
 Attempts to retrieve the value for the given feature as an unsigned 8-bit integer.
static int32 GetInteger (UPARAM(ref) const FCesiumPropertyTableProperty &Property, int64 FeatureID, int32 DefaultValue=0)
 Attempts to retrieve the value for the given feature as a signed 32-bit integer.
static int64 GetInteger64 (UPARAM(ref) const FCesiumPropertyTableProperty &Property, int64 FeatureID, int64 DefaultValue=0)
 Attempts to retrieve the value for the given feature as a signed 64-bit integer.
static float GetFloat (UPARAM(ref) const FCesiumPropertyTableProperty &Property, int64 FeatureID, float DefaultValue=0.0f)
 Attempts to retrieve the value for the given feature as a single-precision floating-point number.
static double GetFloat64 (UPARAM(ref) const FCesiumPropertyTableProperty &Property, int64 FeatureID, double DefaultValue=0.0)
 Attempts to retrieve the value for the given feature as a double-precision floating-point number.
static FIntPoint GetIntPoint (UPARAM(ref) const FCesiumPropertyTableProperty &Property, int64 FeatureID, const FIntPoint &DefaultValue)
 Attempts to retrieve the value for the given feature as a FIntPoint.
static FVector2D GetVector2D (UPARAM(ref) const FCesiumPropertyTableProperty &Property, int64 FeatureID, const FVector2D &DefaultValue)
 Attempts to retrieve the value for the given feature as a FVector2D.
static FIntVector GetIntVector (UPARAM(ref) const FCesiumPropertyTableProperty &Property, int64 FeatureID, const FIntVector &DefaultValue)
 Attempts to retrieve the value for the given feature as a FIntVector.
static FVector3f GetVector3f (UPARAM(ref) const FCesiumPropertyTableProperty &Property, int64 FeatureID, const FVector3f &DefaultValue)
 Attempts to retrieve the value for the given feature as a FVector3f.
static FVector GetVector (UPARAM(ref) const FCesiumPropertyTableProperty &Property, int64 FeatureID, const FVector &DefaultValue)
 Attempts to retrieve the value for the given feature as a FVector.
static FVector4 GetVector4 (UPARAM(ref) const FCesiumPropertyTableProperty &Property, int64 FeatureID, const FVector4 &DefaultValue)
 Attempts to retrieve the value for the given feature as a FVector4.
static FMatrix GetMatrix (UPARAM(ref) const FCesiumPropertyTableProperty &Property, int64 FeatureID, const FMatrix &DefaultValue)
 Attempts to retrieve the value for the given feature as a FMatrix.
static FString GetString (UPARAM(ref) const FCesiumPropertyTableProperty &Property, int64 FeatureID, const FString &DefaultValue="")
 Attempts to retrieve the value for the given feature as a FString.
static FCesiumPropertyArray GetArray (UPARAM(ref) const FCesiumPropertyTableProperty &Property, int64 FeatureID)
 Attempts to retrieve the value for the given feature as a FCesiumPropertyArray.
static FCesiumMetadataValue GetValue (UPARAM(ref) const FCesiumPropertyTableProperty &Property, int64 FeatureID)
 Retrieves the value of the property for the given feature.
static PRAGMA_DISABLE_DEPRECATION_WARNINGS FCesiumMetadataValue GetGenericValue (UPARAM(ref) const FCesiumPropertyTableProperty &Property, int64 FeatureID)
static PRAGMA_ENABLE_DEPRECATION_WARNINGS FCesiumMetadataValue GetRawValue (UPARAM(ref) const FCesiumPropertyTableProperty &Property, int64 FeatureID)
 Retrieves the raw value of the property for the given feature.
static bool IsNormalized (UPARAM(ref) const FCesiumPropertyTableProperty &Property)
 Whether this property is normalized.
static FCesiumMetadataValue GetOffset (UPARAM(ref) const FCesiumPropertyTableProperty &Property)
 Gets the offset of this property.
static FCesiumMetadataValue GetScale (UPARAM(ref) const FCesiumPropertyTableProperty &Property)
 Gets the scale of this property.
static FCesiumMetadataValue GetMinimumValue (UPARAM(ref) const FCesiumPropertyTableProperty &Property)
 Gets the minimum value of this property.
static FCesiumMetadataValue GetMaximumValue (UPARAM(ref) const FCesiumPropertyTableProperty &Property)
 Gets the maximum value of this property.
static FCesiumMetadataValue GetNoDataValue (UPARAM(ref) const FCesiumPropertyTableProperty &Property)
 Gets the "no data" value of this property, as defined by its class property.
static FCesiumMetadataValue GetDefaultValue (UPARAM(ref) const FCesiumPropertyTableProperty &Property)
 Gets the default value of this property, as defined by its class property.
Definition at line 130 of file CesiumPropertyTableProperty.h.
◆ GetArray()
static FCesiumPropertyArray UCesiumPropertyTablePropertyBlueprintLibrary::GetArray ( UPARAM(ref) const FCesiumPropertyTableProperty & Property,
int64 FeatureID )
static
If the property is not an array type, this returns an empty array.
For numeric array properties, the raw array value for a given feature will be transformed by the property's normalization, scale, and offset before it is further converted. If the raw value is equal to the property's "no data" value, then the property's default value will be converted if possible. If the property-defined default value cannot be converted, or does not exist, then the user-defined default value is returned.
PropertyThe property table property.
FeatureIDThe ID of the feature.
The property value as a FCesiumPropertyArray.
◆ GetArrayElementBlueprintType()
static ECesiumMetadataBlueprintType UCesiumPropertyTablePropertyBlueprintLibrary::GetArrayElementBlueprintType ( UPARAM(ref) const FCesiumPropertyTableProperty & Property)
static
If the given property does not contain array values, this returns None.
◆ GetArraySize()
static PRAGMA_ENABLE_DEPRECATION_WARNINGS int64 UCesiumPropertyTablePropertyBlueprintLibrary::GetArraySize ( UPARAM(ref) const FCesiumPropertyTableProperty & Property)
static
Only applicable when the property is a fixed-length array type.
◆ GetBlueprintComponentType()
static PRAGMA_DISABLE_DEPRECATION_WARNINGS ECesiumMetadataBlueprintType UCesiumPropertyTablePropertyBlueprintLibrary::GetBlueprintComponentType ( UPARAM(ref) const FCesiumPropertyTableProperty & Property)
static
◆ GetBlueprintType()
static ECesiumMetadataBlueprintType UCesiumPropertyTablePropertyBlueprintLibrary::GetBlueprintType ( UPARAM(ref) const FCesiumPropertyTableProperty & Property)
static
For the most precise representation of the values possible in Blueprints, you should retrieve it using this type.
◆ GetBoolean()
static PRAGMA_ENABLE_DEPRECATION_WARNINGS bool UCesiumPropertyTablePropertyBlueprintLibrary::GetBoolean ( UPARAM(ref) const FCesiumPropertyTableProperty & Property,
int64 FeatureID,
bool DefaultValue = false )
static
For numeric properties, the raw value for a given feature will be transformed by the property's normalization, scale, and offset before it is further converted. If the raw value is equal to the property's "no data" value, then the property's default value will be converted if possible. If the property-defined default value cannot be converted, or does not exist, then the user-defined default value is returned.
Property values are converted as follows:
  • If the value is a boolean, it is returned as-is.
  • If the value is a scalar, zero is converted to false, while any other value is converted to true.
  • If the value is a string, "0", "false", and "no" (case-insensitive) are converted to false, while "1", "true", and "yes" are converted to true. All other strings, including strings that can be converted to numbers, will return the user-defined default value.
All other types return the user-defined default value. If the feature ID is out-of-range, or if the property table property is somehow invalid, the user-defined default value is returned.
DefaultValueThe default value to fall back on.
The property value as a Boolean.
◆ GetByte()
static uint8 UCesiumPropertyTablePropertyBlueprintLibrary::GetByte ( UPARAM(ref) const FCesiumPropertyTableProperty & Property,
int64 FeatureID,
uint8 DefaultValue = 0 )
static
  • If the value is an integer between 0 and 255, it is returned as-is. Otherwise, if the value is a floating-point number in the aforementioned range, it is truncated (rounded toward zero) and returned.
  • If the value is a boolean, 1 is returned for true and 0 for false.
  • If the value is a string and the entire string can be parsed as an integer between 0 and 255, the parsed value is returned. The string is parsed in a locale-independent way and does not support the use of commas or other delimiters to group digits together.
In all other cases, the user-defined default value is returned. If the feature ID is out-of-range, or if the property table property is somehow invalid, the user-defined default value is returned.
The property value as a Byte.
◆ GetComponentCount()
static PRAGMA_DISABLE_DEPRECATION_WARNINGS int64 UCesiumPropertyTablePropertyBlueprintLibrary::GetComponentCount ( UPARAM(ref) const FCesiumPropertyTableProperty & Property)
static
◆ GetDefaultValue()
static FCesiumMetadataValue UCesiumPropertyTablePropertyBlueprintLibrary::GetDefaultValue ( UPARAM(ref) const FCesiumPropertyTableProperty & Property)
static
This default value is used use when encountering a "no data" value in the property.
If a default value is not defined, this returns an empty value.
The default value of the property.
◆ GetFloat()
static float UCesiumPropertyTablePropertyBlueprintLibrary::GetFloat ( UPARAM(ref) const FCesiumPropertyTableProperty & Property,
int64 FeatureID,
float DefaultValue = 0.0f )
static
  • If the value is already a single-precision floating-point number, it is returned as-is.
  • If the value is a scalar of any other type within the range of values that a single-precision float can represent, it is converted to its closest representation as a single-precision float and returned.
  • If the value is a boolean, 1.0f is returned for true and 0.0f for false.
  • If the value is a string, and the entire string can be parsed as a number, the parsed value is returned. The string is parsed in a locale-independent way and does not support the use of a comma or other delimiter to group digits together.
The property value as a Float.
◆ GetFloat64()
static double UCesiumPropertyTablePropertyBlueprintLibrary::GetFloat64 ( UPARAM(ref) const FCesiumPropertyTableProperty & Property,
int64 FeatureID,
double DefaultValue = 0.0 )
static
  • If the value is a single- or double-precision floating-point number, it is returned as-is.
  • If the value is an integer, it is converted to the closest representable double-precision floating-point number.
  • If the value is a boolean, 1.0 is returned for true and 0.0 for false.
  • If the value is a string and the entire string can be parsed as a number, the parsed value is returned. The string is parsed in a locale-independent way and does not support the use of commas or other delimiters to group digits together.
The property value as a Float64.
◆ GetGenericValue()
static PRAGMA_DISABLE_DEPRECATION_WARNINGS FCesiumMetadataValue UCesiumPropertyTablePropertyBlueprintLibrary::GetGenericValue ( UPARAM(ref) const FCesiumPropertyTableProperty & Property,
int64 FeatureID )
static
This allows the value to be acted on more generically; its true value can be retrieved later as a specific Blueprints type.
The property value.
◆ GetInteger()
static int32 UCesiumPropertyTablePropertyBlueprintLibrary::GetInteger ( UPARAM(ref) const FCesiumPropertyTableProperty & Property,
int64 FeatureID,
int32 DefaultValue = 0 )
static
  • If the value is an integer between -2,147,483,648 and 2,147,483,647, it is returned as-is. Otherwise, if the value is a floating-point number in the aforementioned range, it is truncated (rounded toward zero) and returned.
  • If the value is a string and the entire string can be parsed as an integer in the valid range, the parsed value is returned. If it can be parsed as a floating-point number, the parsed value is truncated (rounded toward zero). In either case, the string is parsed in a locale-independent way and does not support the use of commas or other delimiters to group digits together.
The property value as an Integer.
◆ GetInteger64()
static int64 UCesiumPropertyTablePropertyBlueprintLibrary::GetInteger64 ( UPARAM(ref) const FCesiumPropertyTableProperty & Property,
int64 FeatureID,
int64 DefaultValue = 0 )
static
  • If the value is an integer and between -2^63 and (2^63 - 1), it is returned as-is. Otherwise, if the value is a floating-point number in the aforementioned range, it is truncated (rounded toward zero) and returned.
The property value as an Integer64.
◆ GetIntPoint()
static FIntPoint UCesiumPropertyTablePropertyBlueprintLibrary::GetIntPoint ( UPARAM(ref) const FCesiumPropertyTableProperty & Property,
int64 FeatureID,
const FIntPoint & DefaultValue )
static
  • If the value is a 2-dimensional vector, its components will be converted to 32-bit signed integers if possible.
  • If the value is a 3- or 4-dimensional vector, it will use the first two components to construct the FIntPoint.
  • If the value is a scalar that can be converted to a 32-bit signed integer, the resulting FIntPoint will have this value in both of its components.
  • If the value is a boolean, (1, 1) is returned for true, while (0, 0) is returned for false.
  • If the value is a string that can be parsed as a FIntPoint, the parsed value is returned. The string must be formatted as "X=... Y=...".
In all other cases, the user-defined default value is returned. In all vector cases, if any of the relevant components cannot be represented as a 32-bit signed, the default value is returned.
The property value as a FIntPoint.
◆ GetIntVector()
static FIntVector UCesiumPropertyTablePropertyBlueprintLibrary::GetIntVector ( UPARAM(ref) const FCesiumPropertyTableProperty & Property,
int64 FeatureID,
const FIntVector & DefaultValue )
static
  • If the value is a 3-dimensional vector, its components will be converted to 32-bit signed integers if possible.
  • If the value is a 4-dimensional vector, it will use the first three components to construct the FIntVector.
  • If the value is a 2-dimensional vector, it will become the XY-components of the FIntVector. The Z component will be set to zero.
  • If the value is a scalar that can be converted to a 32-bit signed integer, the resulting FIntVector will have this value in all of its components.
  • If the value is a boolean, (1, 1, 1) is returned for true, while (0, 0, 0) is returned for false.
  • If the value is a string that can be parsed as a FIntVector, the parsed value is returned. The string must be formatted as "X=... Y=... Z=".
In all other cases, the user-defined default value is returned. In all vector cases, if any of the relevant components cannot be represented as a 32-bit signed integer, the default value is returned.
The property value as a FIntVector.
◆ GetMatrix()
static FMatrix UCesiumPropertyTablePropertyBlueprintLibrary::GetMatrix ( UPARAM(ref) const FCesiumPropertyTableProperty & Property,
int64 FeatureID,
const FMatrix & DefaultValue )
static
  • If the value is a 4-by-4 matrix, its components will be converted to double-precision floating-point numbers.
  • If the value is a 3-by-3 matrix, it will initialize the corresponding entries of the FMatrix, while all other entries are set to zero. In other words, the 3-by-3 matrix is returned in an FMatrix where the fourth row and column are filled with zeroes.
  • If the value is a 2-by-2 matrix, it will initialize the corresponding entries of the FMatrix, while all other entries are set to zero. In other words, the 2-by-2 matrix is returned in an FMatrix where the third and fourth rows / columns are filled with zeroes.
  • If the value is a scalar, then the resulting FMatrix will have this value along its diagonal, including the very last component. All other entries will be zero.
  • If the value is a boolean, it is converted to 1.0 for true and 0.0 for false. Then, the resulting FMatrix will have this value along its diagonal, including the very last component. All other entries will be zero.
The property value as a FMatrix.
◆ GetMaximumValue()
static FCesiumMetadataValue UCesiumPropertyTablePropertyBlueprintLibrary::GetMaximumValue ( UPARAM(ref) const FCesiumPropertyTableProperty & Property)
static
This can be defined by the class property that it implements, or overridden by the instance of the property itself.
This is only applicable to scalar, vecN and matN properties. It represents the component-wise maximum of all property values with normalization, offset, and scale applied. If a maximum value is not defined or applicable, this returns an empty value.
The maximum value of the property.
◆ GetMinimumValue()
static FCesiumMetadataValue UCesiumPropertyTablePropertyBlueprintLibrary::GetMinimumValue ( UPARAM(ref) const FCesiumPropertyTableProperty & Property)
static
This is only applicable to scalar, vecN and matN properties. It represents the component-wise minimum of all property values with normalization, offset, and scale applied. If a minimum value is not defined or applicable, this returns an empty value.
The minimum value of the property.
◆ GetNoDataValue()
static FCesiumMetadataValue UCesiumPropertyTablePropertyBlueprintLibrary::GetNoDataValue ( UPARAM(ref) const FCesiumPropertyTableProperty & Property)
static
This value functions a sentinel value, indicating missing data wherever it appears. The value is compared against the property's raw data, without normalization, offset, or scale applied.
This is not applicable to boolean properties. If a "no data" value is not defined or applicable, this returns an empty value.
The "no data" value of the property.
◆ GetNumberOfFeatures()
static PRAGMA_DISABLE_DEPRECATION_WARNINGS int64 UCesiumPropertyTablePropertyBlueprintLibrary::GetNumberOfFeatures ( UPARAM(ref) const FCesiumPropertyTableProperty & Property)
static
◆ GetOffset()
static FCesiumMetadataValue UCesiumPropertyTablePropertyBlueprintLibrary::GetOffset ( UPARAM(ref) const FCesiumPropertyTableProperty & Property)
static
This is only applicable to properties with floating-point or normalized integer component types. If an offset is not defined or applicable, this returns an empty value.
The offset of the property.
◆ GetPropertySize()
static PRAGMA_ENABLE_DEPRECATION_WARNINGS int64 UCesiumPropertyTablePropertyBlueprintLibrary::GetPropertySize ( UPARAM(ref) const FCesiumPropertyTableProperty & Property)
static
◆ GetPropertyTablePropertyStatus()
static ECesiumPropertyTablePropertyStatus UCesiumPropertyTablePropertyBlueprintLibrary::GetPropertyTablePropertyStatus ( UPARAM(ref) const FCesiumPropertyTableProperty & Property)
static
If this property table property is invalid in any way, this will briefly indicate why.
◆ GetRawValue()
static PRAGMA_ENABLE_DEPRECATION_WARNINGS FCesiumMetadataValue UCesiumPropertyTablePropertyBlueprintLibrary::GetRawValue ( UPARAM(ref) const FCesiumPropertyTableProperty & Property,
int64 FeatureID )
static
This is the value of the property without normalization, offset, or scale applied.
If this property specifies a "no data" value, and the raw value is equal to this "no data" value, the value is returned as-is.
If this property is an empty property with a specified default value, it will not have any raw data to retrieve. The returned value will be empty.
The raw property value.
◆ GetScale()
static FCesiumMetadataValue UCesiumPropertyTablePropertyBlueprintLibrary::GetScale ( UPARAM(ref) const FCesiumPropertyTableProperty & Property)
static
This is only applicable to properties with floating-point or normalized integer component types. If a scale is not defined or applicable, this returns an empty value.
The scale of the property.
◆ GetString()
static FString UCesiumPropertyTablePropertyBlueprintLibrary::GetString ( UPARAM(ref) const FCesiumPropertyTableProperty & Property,
int64 FeatureID,
const FString & DefaultValue = "" )
static
  • String properties are returned as-is.
  • Scalar values are converted to a string with std::to_string.
  • Boolean properties are converted to "true" or "false".
  • Vector properties are returned as strings in the format "X=... Y=... Z=... W=..." depending on how many components they have.
  • Matrix properties are returned as strings row-by-row, where each row's values are printed between square brackets. For example, a 2-by-2 matrix will be printed out as "[A B] [C D]".
  • Array properties return the user-defined default value.
The property value as a FString.
◆ GetTrueComponentType()
static ECesiumMetadataTrueType_DEPRECATED UCesiumPropertyTablePropertyBlueprintLibrary::GetTrueComponentType ( UPARAM(ref) const FCesiumPropertyTableProperty & Value)
static
If this is not an array property, the component type will be None. Many of these types are not accessible from Blueprints, but can be converted to a Blueprint-accessible type.
ValueThe property table property.
◆ GetTrueType()
static PRAGMA_DISABLE_DEPRECATION_WARNINGS ECesiumMetadataTrueType_DEPRECATED UCesiumPropertyTablePropertyBlueprintLibrary::GetTrueType ( UPARAM(ref) const FCesiumPropertyTableProperty & Value)
static
◆ GetValue()
static FCesiumMetadataValue UCesiumPropertyTablePropertyBlueprintLibrary::GetValue ( UPARAM(ref) const FCesiumPropertyTableProperty & Property,
int64 FeatureID )
static
For numeric properties, the raw value for a given feature will be transformed by the property's normalization, scale, and offset before it is returned. If the raw value is equal to the property's "no data" value, an empty value will be returned. However, if the property itself specifies a default value, then the property-defined default value will be returned.
The property value.
◆ GetValueType()
static PRAGMA_ENABLE_DEPRECATION_WARNINGS FCesiumMetadataValueType UCesiumPropertyTablePropertyBlueprintLibrary::GetValueType ( UPARAM(ref) const FCesiumPropertyTableProperty & Property)
static
◆ GetVector()
static FVector UCesiumPropertyTablePropertyBlueprintLibrary::GetVector ( UPARAM(ref) const FCesiumPropertyTableProperty & Property,
int64 FeatureID,
const FVector & DefaultValue )
static
  • If the value is a 3-dimensional vector, its components will be converted to double-precision floating-point numbers.
  • If the value is a 4-dimensional vector, a FVector containing the first three components will be returned.
  • If the value is a 2-dimensional vector, it will become the XY-components of the FVector. The Z-component will be set to zero.
  • If the value is a scalar, then the resulting FVector will have this value as a double-precision floating-point number in all of its components.
  • If the value is a boolean, (1.0, 1.0, 1.0) is returned for true, while (0.0, 0.0, 0.0) is returned for false.
  • If the value is a string that can be parsed as a FVector, the parsed value is returned. The string must be formatted as "X=... Y=... Z=".
The property value as a FVector.
◆ GetVector2D()
static FVector2D UCesiumPropertyTablePropertyBlueprintLibrary::GetVector2D ( UPARAM(ref) const FCesiumPropertyTableProperty & Property,
int64 FeatureID,
const FVector2D & DefaultValue )
static
  • If the value is a 2-dimensional vector, its components will be converted to double-precision floating-point numbers.
  • If the value is a 3- or 4-dimensional vector, it will use the first two components to construct the FVector2D.
  • If the value is a scalar, the resulting FVector2D will have this value in both of its components.
  • If the value is a boolean, (1.0, 1.0) is returned for true, while (0.0, 0.0) is returned for false.
  • If the value is a string that can be parsed as a FVector2D, the parsed value is returned. The string must be formatted as "X=... Y=...".
The property value as a FVector2D.
◆ GetVector3f()
static FVector3f UCesiumPropertyTablePropertyBlueprintLibrary::GetVector3f ( UPARAM(ref) const FCesiumPropertyTableProperty & Property,
int64 FeatureID,
const FVector3f & DefaultValue )
static
  • If the value is a 3-dimensional vector, its components will be converted to the closest representable single-precision floats, if possible.
  • If the value is a 4-dimensional vector, a FVector3f containing the first three components will be returned.
  • If the value is a 2-dimensional vector, it will become the XY-components of the FVector3f. The Z-component will be set to zero.
  • If the value is a scalar that can be converted to a single-precision floating-point number, then the resulting FVector3f will have this value in all of its components.
  • If the value is a boolean, (1.0f, 1.0f, 1.0f) is returned for true, while (0.0f, 0.0f, 0.0f) is returned for false.
  • If the value is a string that can be parsed as a FVector3f, the parsed value is returned. The string must be formatted as "X=... Y=... Z=".
In all other cases, the user-defined default value is returned. In all vector cases, if any of the relevant components cannot be represented as a single-precision float, the user-defined default value is returned.
The property value as a FVector3f.
◆ GetVector4()
static FVector4 UCesiumPropertyTablePropertyBlueprintLibrary::GetVector4 ( UPARAM(ref) const FCesiumPropertyTableProperty & Property,
int64 FeatureID,
const FVector4 & DefaultValue )
static
  • If the value is a 4-dimensional vector, its components will be converted to double-precision floating-point numbers.
  • If the value is a 3-dimensional vector, it will become the XYZ-components of the FVector4. The W-component will be set to zero.
  • If the value is a 2-dimensional vector, it will become the XY-components of the FVector4. The Z- and W-components will be set to zero.
  • If the value is a scalar, then the resulting FVector4 will have this value as a double-precision floating-point number in all of its components.
  • If the value is a boolean, (1.0, 1.0, 1.0, 1.0) is returned for true, while (0.0, 0.0, 0.0, 0.0) is returned for false.
  • If the value is a string that can be parsed as a FVector4, the parsed value is returned. This follows the rules of FVector4::InitFromString. The string must be formatted as "X=... Y=... Z=... W=...". The W-component is optional; if absent, it will be set to 1.0.
The property value as a FVector4.
◆ IsNormalized()
static bool UCesiumPropertyTablePropertyBlueprintLibrary::IsNormalized ( UPARAM(ref) const FCesiumPropertyTableProperty & Property)
static
Only applicable when this property has an integer component type.
