UCesiumModelMetadataBlueprintLibrary Class Reference
#include <CesiumModelMetadata.h>
Inheritance diagram for UCesiumModelMetadataBlueprintLibrary:
static const FCesiumModelMetadata & GetModelMetadata (const UPrimitiveComponent *component)
 Gets the model metadata of a glTF primitive component.
static PRAGMA_DISABLE_DEPRECATION_WARNINGS const TMap< FString, FCesiumPropertyTable > GetFeatureTables (UPARAM(ref) const FCesiumModelMetadata &ModelMetadata)
 Get all the feature tables for this model metadata.
static const TMap< FString, FCesiumPropertyTexture > GetFeatureTextures (UPARAM(ref) const FCesiumModelMetadata &ModelMetadata)
 Get all the feature textures for this model metadata.
static PRAGMA_ENABLE_DEPRECATION_WARNINGS const TArray< FCesiumPropertyTable > & GetPropertyTables (UPARAM(ref) const FCesiumModelMetadata &ModelMetadata)
 Gets an array of all the property tables for this model metadata.
static const FCesiumPropertyTable & GetPropertyTable (UPARAM(ref) const FCesiumModelMetadata &ModelMetadata, const int64 Index)
 Gets the property table at the specified index for this model metadata.
static const TArray< FCesiumPropertyTable > GetPropertyTablesAtIndices (UPARAM(ref) const FCesiumModelMetadata &ModelMetadata, const TArray< int64 > &Indices)
 Gets the property table at the specified indices for this model metadata.
static const TArray< FCesiumPropertyTexture > & GetPropertyTextures (UPARAM(ref) const FCesiumModelMetadata &ModelMetadata)
 Gets an array of all the property textures for this model metadata.
static const FCesiumPropertyTexture & GetPropertyTexture (UPARAM(ref) const FCesiumModelMetadata &ModelMetadata, const int64 Index)
static const TArray< FCesiumPropertyTexture > GetPropertyTexturesAtIndices (UPARAM(ref) const FCesiumModelMetadata &ModelMetadata, const TArray< int64 > &Indices)
 Gets an array of the property textures at the specified indices for this model metadata.
Definition at line 45 of file CesiumModelMetadata.h.
◆ GetFeatureTables()
static PRAGMA_DISABLE_DEPRECATION_WARNINGS const TMap< FString, FCesiumPropertyTable > UCesiumModelMetadataBlueprintLibrary::GetFeatureTables ( UPARAM(ref) const FCesiumModelMetadata & ModelMetadata)
static
◆ GetFeatureTextures()
static const TMap< FString, FCesiumPropertyTexture > UCesiumModelMetadataBlueprintLibrary::GetFeatureTextures ( UPARAM(ref) const FCesiumModelMetadata & ModelMetadata)
static
◆ GetModelMetadata()
static const FCesiumModelMetadata & UCesiumModelMetadataBlueprintLibrary::GetModelMetadata ( const UPrimitiveComponent * component)
static
If component is not a Cesium glTF primitive component, the returned metadata is empty.
◆ GetPropertyTable()
static const FCesiumPropertyTable & UCesiumModelMetadataBlueprintLibrary::GetPropertyTable ( UPARAM(ref) const FCesiumModelMetadata & ModelMetadata,
const int64 Index )
static
If the index is out-of-bounds, this returns an invalid property table.
◆ GetPropertyTables()
static PRAGMA_ENABLE_DEPRECATION_WARNINGS const TArray< FCesiumPropertyTable > & UCesiumModelMetadataBlueprintLibrary::GetPropertyTables ( UPARAM(ref) const FCesiumModelMetadata & ModelMetadata)
static
◆ GetPropertyTablesAtIndices()
static const TArray< FCesiumPropertyTable > UCesiumModelMetadataBlueprintLibrary::GetPropertyTablesAtIndices ( UPARAM(ref) const FCesiumModelMetadata & ModelMetadata,
const TArray< int64 > & Indices )
static
An invalid property table will be returned for any out-of-bounds index.
◆ GetPropertyTexture()
static const FCesiumPropertyTexture & UCesiumModelMetadataBlueprintLibrary::GetPropertyTexture ( UPARAM(ref) const FCesiumModelMetadata & ModelMetadata,
const int64 Index )
static
◆ GetPropertyTextures()
static const TArray< FCesiumPropertyTexture > & UCesiumModelMetadataBlueprintLibrary::GetPropertyTextures ( UPARAM(ref) const FCesiumModelMetadata & ModelMetadata)
static
◆ GetPropertyTexturesAtIndices()
static const TArray< FCesiumPropertyTexture > UCesiumModelMetadataBlueprintLibrary::GetPropertyTexturesAtIndices ( UPARAM(ref) const FCesiumModelMetadata & ModelMetadata,
static
