UCesiumMetadataPickingBlueprintLibrary Class Reference
#include <CesiumMetadataPickingBlueprintLibrary.h>
Inheritance diagram for UCesiumMetadataPickingBlueprintLibrary:
static bool FindUVFromHit (const FHitResult &Hit, int64 GltfTexCoordSetIndex, FVector2D &UV)
 Compute the UV coordinates from the given line trace hit, assuming it has hit a glTF primitive component that contains the specified texture coordinate set.
static TMap< FString, FCesiumMetadataValue > GetPropertyTableValuesFromHit (const FHitResult &Hit, int64 FeatureIDSetIndex=0)
 Gets the property table values from a given line trace hit, assuming that it has hit a feature of a glTF primitive component.
static TMap< FString, FCesiumMetadataValue > GetPropertyTextureValuesFromHit (const FHitResult &Hit, int64 PrimitivePropertyTextureIndex=0)
 Gets the property texture values from a given line trace hit, assuming it has hit a glTF primitive component.
static PRAGMA_DISABLE_DEPRECATION_WARNINGS TMap< FString, FCesiumMetadataValue > GetMetadataValuesForFace (const UPrimitiveComponent *Component, int64 FaceIndex, int64 FeatureIDSetIndex=0)
 Gets the metadata values for a face on a glTF primitive component.
static TMap< FString, FString > GetMetadataValuesForFaceAsStrings (const UPrimitiveComponent *Component, int64 FaceIndex, int64 FeatureIDSetIndex=0)
 Gets the metadata values for a face on a glTF primitive component, as strings.
static PRAGMA_ENABLE_DEPRECATION_WARNINGS const FCesiumPropertyTableProperty & FindPropertyTableProperty (const UPrimitiveComponent *Component, const FString &PropertyName, int64 FeatureIDSetIndex=0)
 Retrieves a property table property from the component by name.
static const FCesiumPropertyTableProperty & FindPropertyTableProperty (const FCesiumPrimitiveFeatures &Features, const FCesiumModelMetadata &Metadata, const FString &PropertyName, int64 FeatureIDSetIndex)
 Retrieves a property table property by name, from the primitive features and the model metadata.
Definition at line 17 of file CesiumMetadataPickingBlueprintLibrary.h.
◆ FindPropertyTableProperty() [1/2]
static const FCesiumPropertyTableProperty & UCesiumMetadataPickingBlueprintLibrary::FindPropertyTableProperty ( const FCesiumPrimitiveFeatures & Features,
const FCesiumModelMetadata & Metadata,
const FString & PropertyName,
int64 FeatureIDSetIndex )
static
If the specified feature ID set does not exist or if the property table does not contain a property with that name, the returned property will be invalid.
◆ FindPropertyTableProperty() [2/2]
static PRAGMA_ENABLE_DEPRECATION_WARNINGS const FCesiumPropertyTableProperty & UCesiumMetadataPickingBlueprintLibrary::FindPropertyTableProperty ( const UPrimitiveComponent * Component,
int64 FeatureIDSetIndex = 0 )
static
◆ FindUVFromHit()
static bool UCesiumMetadataPickingBlueprintLibrary::FindUVFromHit ( const FHitResult & Hit,
FVector2D & UV )
static
The texture coordinate set is specified relative to the glTF itself, where the set index N resolves to the "TEXCOORD_N" attribute in the glTF primitive.
This function can be used to sample feature ID textures or property textures in the primitive. This works similarly to the FindCollisionUV Blueprint, except it does not require the texture coordinate sets to be present in the model's physics mesh.
Returns false if the given texture coordinate set index does not exist for the primitive, or if its accessor is invalid.
◆ GetMetadataValuesForFace()
static PRAGMA_DISABLE_DEPRECATION_WARNINGS TMap< FString, FCesiumMetadataValue > UCesiumMetadataPickingBlueprintLibrary::GetMetadataValuesForFace ( const UPrimitiveComponent * Component,
int64 FaceIndex,
static
A primitive may have multiple feature ID sets, so this allows a feature ID set to be specified by index. This value should index into the array of CesiumFeatureIdSets in the component's CesiumPrimitiveFeatures. If the feature ID set is associated with a property table, it will return that property table's data.
For feature ID textures and implicit feature IDs, the feature ID can vary across the face of a primitive. If the specified CesiumFeatureIdSet is one of those types, the feature ID of the first vertex on the face will be used.
The returned result may be empty for several reasons:
  • if the component is not a Cesium glTF primitive component
  • if the given face index is out-of-bounds
  • if the specified feature ID set does not exist on the primitive
  • if the specified feature ID set is not associated with a valid property table
Additionally, if any of the property table's properties are invalid, they will not be included in the result.
◆ GetMetadataValuesForFaceAsStrings()
static TMap< FString, FString > UCesiumMetadataPickingBlueprintLibrary::GetMetadataValuesForFaceAsStrings ( const UPrimitiveComponent * Component,
int64 FaceIndex,
static
Additionally, if any of the property table's properties are invalid, they will not be included in the result. Array properties will return empty strings.
◆ GetPropertyTableValuesFromHit()
static TMap< FString, FCesiumMetadataValue > UCesiumMetadataPickingBlueprintLibrary::GetPropertyTableValuesFromHit ( const FHitResult & Hit,
static
  • if the hit's face index is somehow out-of-bounds
◆ GetPropertyTextureValuesFromHit()
static TMap< FString, FCesiumMetadataValue > UCesiumMetadataPickingBlueprintLibrary::GetPropertyTextureValuesFromHit ( const FHitResult & Hit,
int64 PrimitivePropertyTextureIndex = 0 )
static
A primitive may use multiple property textures, as indicated by its indices in CesiumPrimitiveMetadata. This function allows for selection of which property texture to use from those available in CesiumPrimitiveMetadata.
In other words, the "Primitive Property Texture Index" should index into the array property texture indices in the CesiumPrimitiveMetadata. The primitive metadata will not necessarily contain all of the available property textures in the CesiumModelMetadata, nor will it necessarily be listed in the same order.
  • if the given primitive property texture index is out-of-bounds
  • if the property texture index derived from CesiumPrimitiveMetadata is out-of-bounds
Additionally, if any of the property texture's properties are invalid, they will not be included in the result.
