UCesiumFeatureIdSetBlueprintLibrary Class Reference
#include <CesiumFeatureIdSet.h>
Inheritance diagram for UCesiumFeatureIdSetBlueprintLibrary:
static const ECesiumFeatureIdSetType GetFeatureIDSetType (UPARAM(ref) const FCesiumFeatureIdSet &FeatureIDSet)
 Gets the type of this feature ID set.
static const FCesiumFeatureIdAttribute & GetAsFeatureIDAttribute (UPARAM(ref) const FCesiumFeatureIdSet &FeatureIDSet)
 Gets this feature ID set as a feature ID attribute.
static const FCesiumFeatureIdTexture & GetAsFeatureIDTexture (UPARAM(ref) const FCesiumFeatureIdSet &FeatureIDSet)
 Gets this feature ID set as a feature ID texture.
static const int64 GetPropertyTableIndex (UPARAM(ref) const FCesiumFeatureIdSet &FeatureIDSet)
 Get the index of the property table corresponding to this feature ID set.
static int64 GetFeatureCount (UPARAM(ref) const FCesiumFeatureIdSet &FeatureIDSet)
 Get the number of features this primitive has.
static const int64 GetNullFeatureID (UPARAM(ref) const FCesiumFeatureIdSet &FeatureIDSet)
 Gets the null feature ID, i.e., the value that indicates no feature is associated with the owner.
static const FString GetLabel (UPARAM(ref) const FCesiumFeatureIdSet &FeatureIDSet)
 Gets the label assigned to this feature ID set.
static int64 GetFeatureIDForVertex (UPARAM(ref) const FCesiumFeatureIdSet &FeatureIDSet, int64 VertexIndex)
 Gets the feature ID associated with a given vertex.
static int64 GetFeatureIDForInstance (UPARAM(ref) const FCesiumFeatureIdSet &FeatureIDSet, int64 InstanceIndex)
 Gets the feature ID associated with a given instance in glTF models using the EXT_mesh_gpu_instancing and EXT_instance_features extensions.
static int64 GetFeatureIDFromHit (UPARAM(ref) const FCesiumFeatureIdSet &FeatureIDSet, const FHitResult &Hit)
 Given a trace hit result, gets the feature ID from the feature ID set on the hit component.
Definition at line 75 of file CesiumFeatureIdSet.h.
◆ GetAsFeatureIDAttribute()
static const FCesiumFeatureIdAttribute & UCesiumFeatureIdSetBlueprintLibrary::GetAsFeatureIDAttribute ( UPARAM(ref) const FCesiumFeatureIdSet & FeatureIDSet)
static
This can be used for more fine-grained interaction with the attribute itself. If this feature ID is not defined as an attribute, then the returned attribute will be invalid.
◆ GetAsFeatureIDTexture()
static const FCesiumFeatureIdTexture & UCesiumFeatureIdSetBlueprintLibrary::GetAsFeatureIDTexture ( UPARAM(ref) const FCesiumFeatureIdSet & FeatureIDSet)
static
This can be used for more fine-grained interaction with the texture itself. If this feature ID is not defined as a texture, then the returned texture will be invalid.
◆ GetFeatureCount()
static int64 UCesiumFeatureIdSetBlueprintLibrary::GetFeatureCount ( UPARAM(ref) const FCesiumFeatureIdSet & FeatureIDSet)
static
◆ GetFeatureIDForInstance()
static int64 UCesiumFeatureIdSetBlueprintLibrary::GetFeatureIDForInstance ( UPARAM(ref) const FCesiumFeatureIdSet & FeatureIDSet,
int64 InstanceIndex )
static
The feature ID can be used with a FCesiumPropertyTable to retrieve the corresponding metadata.
This returns -1 if the given instance is out-of-bounds, if the feature ID set is not for instances, or if the feature ID set is invalid (e.g., it contains an invalid feature ID attribute).
◆ GetFeatureIDForVertex()
static int64 UCesiumFeatureIdSetBlueprintLibrary::GetFeatureIDForVertex ( UPARAM(ref) const FCesiumFeatureIdSet & FeatureIDSet,
int64 VertexIndex )
static
This returns -1 if the given vertex is out-of-bounds, or if the feature ID set is invalid (e.g., it contains an invalid feature ID texture).
◆ GetFeatureIDFromHit()
static int64 UCesiumFeatureIdSetBlueprintLibrary::GetFeatureIDFromHit ( UPARAM(ref) const FCesiumFeatureIdSet & FeatureIDSet,
const FHitResult & Hit )
static
This returns a more accurate value for feature ID textures, since they define feature IDs per-texel instead of per-vertex. The feature ID can be used with a FCesiumPropertyTable to retrieve the corresponding metadata.
This can still retrieve the feature IDs for non-texture feature ID sets. For attribute or implicit feature IDs, the first feature ID associated with the first vertex of the intersected face is returned.
This returns -1 if the feature ID set is invalid (e.g., it contains an invalid feature ID texture).
◆ GetFeatureIDSetType()
static const ECesiumFeatureIdSetType UCesiumFeatureIdSetBlueprintLibrary::GetFeatureIDSetType ( UPARAM(ref) const FCesiumFeatureIdSet & FeatureIDSet)
static
◆ GetLabel()
static const FString UCesiumFeatureIdSetBlueprintLibrary::GetLabel ( UPARAM(ref) const FCesiumFeatureIdSet & FeatureIDSet)
static
If no label was present in the glTF feature ID set, this returns an empty string.
◆ GetNullFeatureID()
static const int64 UCesiumFeatureIdSetBlueprintLibrary::GetNullFeatureID ( UPARAM(ref) const FCesiumFeatureIdSet & FeatureIDSet)
static
In other words, if a vertex or texel returns this value, then it is not associated with any feature.
If this value was not defined in the glTF feature ID set, this defaults to -1.
◆ GetPropertyTableIndex()
static const int64 UCesiumFeatureIdSetBlueprintLibrary::GetPropertyTableIndex ( UPARAM(ref) const FCesiumFeatureIdSet & FeatureIDSet)
static
The index can be used to fetch the appropriate FCesiumPropertyTable from the FCesiumModelMetadata. If the feature ID set does not specify a property table, this returns -1.
