CesiumCamera.h
5#include "Camera/CameraComponent.h"
6#include "Math/Rotator.h"
7#include "Math/Vector.h"
8#include "Math/Vector2D.h"
9#include "UObject/ObjectMacros.h"
10
11#include "Cesium3DTilesSelection/ViewState.h"
12
13#include "CesiumCamera.generated.h"
14
15UENUM(BlueprintType)
16enum class ECameraParameterSource : uint8 {
17 /**
18 * Camera parameters are set explicitly by the user.
19 */
20 Manual UMETA(DisplayName = "Set Manually"),
21
22 /**
23 * Camera parameters come from a camera component
24 */
25 CameraComponent UMETA(DisplayName = "From Camera Component")
26};
27
28/**
29 * @brief A camera description that {@link ACesium3DTileset}s can use to decide
30 * what tiles need to be loaded to sufficiently cover the camera view.
31 */
32USTRUCT(BlueprintType)
33struct CESIUMRUNTIME_API FCesiumCamera {
34 GENERATED_USTRUCT_BODY()
35
36public:
37 /**
38 * @brief The desired source of camera parameters.
39 */
40 UPROPERTY(EditAnywhere, BlueprintReadWrite, Category = "Cesium")
42
43 /**
44 * @brief The pixel dimensions of the viewport.
45 */
46 UPROPERTY(EditAnywhere, BlueprintReadWrite, Category = "Cesium")
47 FVector2D ViewportSize;
48
49 /**
50 * @brief The camera component from which to retrieve parameters. Due to
51 * UI limitations, this property must be set through Blueprints or C++. Used
52 * when ParameterSource is set to Camera Component.
53 */
54 UPROPERTY(
55 EditAnywhere,
56 BlueprintReadWrite,
57 Category = "Cesium",
58 Meta =
59 (EditCondition =
60 "ParameterSource == ECameraParameterSource::CameraComponent"))
61 TSoftObjectPtr<UCameraComponent> CameraComponent;
62
63 /**
64 * @brief The Unreal location of the camera. Used when Parameter Source is set
65 * to Manual.
66 */
67 UPROPERTY(
68 EditAnywhere,
69 BlueprintReadWrite,
70 Category = "Cesium",
71 Meta =
72 (EditCondition = "ParameterSource == ECameraParameterSource::Manual"))
73 FVector Location;
74
75 /**
76 * @brief The Unreal rotation of the camera. Used when Parameter Source is set
77 * to Manual.
78 */
79 UPROPERTY(
80 EditAnywhere,
81 BlueprintReadWrite,
82 Category = "Cesium",
83 Meta =
84 (EditCondition = "ParameterSource == ECameraParameterSource::Manual"))
85 FRotator Rotation;
86
87 /**
88 * @brief The horizontal field of view of the camera in degrees. Used when
89 * Parameter Source is set to Manual.
90 */
91 UPROPERTY(
92 EditAnywhere,
93 BlueprintReadWrite,
94 Category = "Cesium",
95 Meta =
96 (EditCondition = "ParameterSource == ECameraParameterSource::Manual"))
98
99 /**
100 * @brief The overriden aspect ratio for this camera.
101 *
102 * When this is 0.0f, use the aspect ratio implied by ViewportSize.
103 *
104 * This may be different from the aspect ratio implied by the ViewportSize
105 * and black bars are added as needed in order to achieve this aspect ratio
106 * within a larger viewport.
107 */
108 UPROPERTY(BlueprintReadWrite, Category = "Cesium")
110
111 /**
112 * @brief Construct an uninitialized FCesiumCamera object.
113 */
115
116 /**
117 * @brief Construct a new FCesiumCamera object.
118 *
119 * @param ViewportSize The viewport pixel size.
120 * @param Location The Unreal location.
121 * @param Rotation The Unreal rotation.
122 * @param FieldOfViewDegrees The horizontal field of view in degrees.
123 */
125 const FVector2D& ViewportSize,
126 const FVector& Location,
127 const FRotator& Rotation,
128 double FieldOfViewDegrees);
129
130 /**
131 * @brief Construct a new FCesiumCamera object.
132 *
133 * @param ViewportSize The viewport pixel size.
134 * @param Location The Unreal location.
135 * @param Rotation The Unreal rotation.
136 * @param FieldOfViewDegrees The horizontal field of view in degrees.
137 * @param OverrideAspectRatio The overriden aspect ratio.
138 */
140 const FVector2D& ViewportSize,
141 const FVector& Location,
142 const FRotator& Rotation,
143 double FieldOfViewDegrees,
144 double OverrideAspectRatio);
145};
@ UMETA
FVector Location
ECameraParameterSource ParameterSource
TSoftObjectPtr< UCameraComponent > CameraComponent
FRotator Rotation
FCesiumCamera()
