Cesium for Unity 1.26.1
Represents a feature ID set from a glTF primitive. More...
| virtual Int64 | GetFeatureIdForVertex (Int64 vertexIndex) |
| Gets the feature ID associated with a given vertex. | |
| virtual Int64 | GetFeatureIdFromRaycastHit (RaycastHit hitInfo) |
| Gets the feature ID from the feature ID set using the given raycast hit. | |
| virtual void | Dispose () |
Properties | |
| CesiumFeatureIdSetType | type [get, protected set] |
| The type of this feature ID set. | |
| String | label [get, set] |
| The label assigned to this feature ID set. | |
| Int64 | featureCount [get, set] |
| The number of features this primitive has. | |
| Int64 | nullFeatureId [get, set] |
| The null feature ID, i.e., the value that indicates no feature is associated with the owner.In other words, if a vertex or texel returns this value, then it is not associated with any feature. | |
| Int64 | propertyTableIndex [get, set] |
| The index of the property table corresponding to this feature ID set. | |
A feature ID can be defined as a per-vertex attribute, as a feature ID texture, or implicitly via vertex ID. These can be used with the corresponding CesiumPropertyTable to access per-feature metadata.
Definition at line 24 of file CesiumFeatureIdSet.cs.
inlinevirtual |
Definition at line 163 of file CesiumFeatureIdSet.cs.
inlinevirtual |
The feature ID can be used with a CesiumPropertyTable to retrieve the corresponding metadata.
This returns -1 if the given vertex is out-of-bounds, or if the feature ID set is invalid.
| vertexIndex | The index of the target vertex. |
Reimplemented in CesiumForUnity.CesiumFeatureIdAttribute, and CesiumForUnity.CesiumFeatureIdTexture.
Definition at line 110 of file CesiumFeatureIdSet.cs.
inlinevirtual |
This returns a more accurate value for feature ID textures, since they define feature IDs per-texel instead of per-vertex. The feature ID can be used with a CesiumPropertyTable to retrieve the corresponding metadata.
This can still retrieve the feature IDs for non-texture feature ID sets. For attribute or implicit feature IDs, the first feature ID associated with the first vertex of the intersected face is returned.
This returns -1 if the feature ID set is invalid.
| hitInfo | The raycast hit info. |
Definition at line 144 of file CesiumFeatureIdSet.cs.
getset |
Definition at line 48 of file CesiumFeatureIdSet.cs.
getset |
If no label was present in the glTF feature ID set, this returns an empty string.
Definition at line 40 of file CesiumFeatureIdSet.cs.
getset |
If this value was not defined in the glTF feature ID set, this returns -1.
Definition at line 61 of file CesiumFeatureIdSet.cs.
getset |
The index can be used to fetch the appropriate CesiumPropertyTable from the CesiumModelMetadata.
If the feature ID set does not specify a property table, this returns -1.
Definition at line 74 of file CesiumFeatureIdSet.cs.
getprotected set |
Definition at line 31 of file CesiumFeatureIdSet.cs.
