Cesium for Unity 1.26.1
CesiumForUnity.CesiumPropertyTable Class Reference
Represents a glTF property table in the EXT_structural_metadata extension. More...
Dictionary< String, CesiumMetadataValue > GetMetadataValuesForFeature (Int64 featureId)
 Gets all of the property values for a given feature, mapped by property name.
void GetMetadataValuesForFeature (Dictionary< String, CesiumMetadataValue > values, Int64 featureId)
Properties
CesiumPropertyTableStatus status [get, set]
 The status of the property table.
string name [get, set]
 The name of the property table.
Int64 count [get, set]
 The number of values each property in the table is expected to have.
Dictionary< String, CesiumPropertyTableProperty > properties [get, set]
 The properties of the property table, mapped by property id.
A property table is a collection of properties for the features in a mesh. It knows how to look up the metadata values associated with a given feature ID.
Definition at line 34 of file CesiumPropertyTable.cs.
◆ GetMetadataValuesForFeature() [1/2]
void CesiumForUnity.CesiumPropertyTable.GetMetadataValuesForFeature ( Dictionary< String, CesiumMetadataValue > values,
Int64 featureId )
This will only include values from valid property table properties.
Call the overload with a Dictionary parameter if you wish to avoid allocation of a new Dictionary with every access.
If the feature ID is out-of-bounds, the returned dictionary will be empty.
valuesThe dictionary of values that will be cleared and filled by this method.
featureIdThe ID of the feature.
Definition at line 108 of file CesiumPropertyTable.cs.
◆ GetMetadataValuesForFeature() [2/2]
Dictionary< String, CesiumMetadataValue > CesiumForUnity.CesiumPropertyTable.GetMetadataValuesForFeature ( Int64 featureId)
A dictionary of the property values mapped by property name.
Definition at line 86 of file CesiumPropertyTable.cs.
Property Documentation
◆ count
Int64 CesiumForUnity.CesiumPropertyTable.count
getset
If an error occurred while parsing the property table, this returns zero.
Definition at line 58 of file CesiumPropertyTable.cs.
◆ name
string CesiumForUnity.CesiumPropertyTable.name
getset
If no name was specified in the glTF extension, this is an empty string.
Definition at line 49 of file CesiumPropertyTable.cs.
◆ properties
Dictionary<String, CesiumPropertyTableProperty> CesiumForUnity.CesiumPropertyTable.properties
getset
Definition at line 66 of file CesiumPropertyTable.cs.
◆ status
CesiumPropertyTableStatus CesiumForUnity.CesiumPropertyTable.status
getset
If an error occurred while parsing the property table from the glTF extension, this briefly conveys why.
Definition at line 40 of file CesiumPropertyTable.cs.
