Cesium for Unity 1.26.1
CesiumForUnity.CesiumFeatureIdAttribute Class Reference
Represents a feature ID attribute from a glTF primitive. More...
Inheritance diagram for CesiumForUnity.CesiumFeatureIdAttribute:
CesiumForUnity.CesiumFeatureIdSet
override partial Int64 GetFeatureIdForVertex (Int64 vertexIndex)
 Gets the feature ID associated with a given vertex.The feature ID can be used with a CesiumPropertyTable to retrieve the corresponding metadata.This returns -1 if the given vertex is out-of-bounds, or if the feature ID set is invalid.
override Int64 GetFeatureIdFromRaycastHit (RaycastHit hitInfo)
 Gets the feature ID from the feature ID set using the given raycast hit.This returns a more accurate value for feature ID textures, since they define feature IDs per-texel instead of per-vertex. The feature ID can be used with a CesiumPropertyTable to retrieve the corresponding metadata.This can still retrieve the feature IDs for non-texture feature ID sets. For attribute or implicit feature IDs, the first feature ID associated with the first vertex of the intersected face is returned.
This returns -1 if the feature ID set is invalid.
- Public Member Functions inherited from CesiumForUnity.CesiumFeatureIdSet
virtual void Dispose ()
Properties
CesiumFeatureIdAttributeStatus status [get, set]
 The status of this feature ID attribute.
- Properties inherited from CesiumForUnity.CesiumFeatureIdSet
CesiumFeatureIdSetType type [get, protected set]
 The type of this feature ID set.
String label [get, set]
 The label assigned to this feature ID set.
Int64 featureCount [get, set]
 The number of features this primitive has.
Int64 nullFeatureId [get, set]
 The null feature ID, i.e., the value that indicates no feature is associated with the owner.In other words, if a vertex or texel returns this value, then it is not associated with any feature.
Int64 propertyTableIndex [get, set]
 The index of the property table corresponding to this feature ID set.
Provides access to per-vertex feature IDs which can be used with the corresponding CesiumPropertyTable to access per-vertex metadata.
Definition at line 34 of file CesiumFeatureIdAttribute.cs.
◆ GetFeatureIdForVertex()
override partial Int64 CesiumForUnity.CesiumFeatureIdAttribute.GetFeatureIdForVertex ( Int64 vertexIndex)
virtual
Reimplemented from CesiumForUnity.CesiumFeatureIdSet.
◆ GetFeatureIdFromRaycastHit()
override Int64 CesiumForUnity.CesiumFeatureIdAttribute.GetFeatureIdFromRaycastHit ( RaycastHit hitInfo)
inlinevirtual
Definition at line 55 of file CesiumFeatureIdAttribute.cs.
Property Documentation
◆ status
CesiumFeatureIdAttributeStatus CesiumForUnity.CesiumFeatureIdAttribute.status
getset
Definition at line 39 of file CesiumFeatureIdAttribute.cs.
