cesium-native 0.67.0
Enables loading optional metadata schema for GeoJSON properties. More...
#include <CesiumTilesetJson/ExtensionMetadataEntityMaxarContentGeoJson.h>
| std::optional< std::string > | propertiesSchemaUri |
| The URI (or IRI) of the external schema file for feature metadata. | |
| static constexpr const char * | ExtensionName = "MAXAR_content_geojson" |
Definition at line 15 of file ExtensionMetadataEntityMaxarContentGeoJson.h.
Definition at line 37 of file ExtensionMetadataEntityMaxarContentGeoJson.h.
Definition at line 24 of file ExtensionMetadataEntityMaxarContentGeoJson.h.
| std::optional<std::string> CesiumTilesetJson::ExtensionMetadataEntityMaxarContentGeoJson::propertiesSchemaUri |
Definition at line 29 of file ExtensionMetadataEntityMaxarContentGeoJson.h.
Definition at line 20 of file ExtensionMetadataEntityMaxarContentGeoJson.h.
