CesiumTilesetJson::ExtensionContent3dTilesContentVoxels Struct Referencefinal
Voxel content type. More...
#include <CesiumTilesetJson/ExtensionContent3dTilesContentVoxels.h>
Inheritance diagram for CesiumTilesetJson::ExtensionContent3dTilesContentVoxels:
std::vector< int64_t > dimensions
 Dimensions of the voxel grid. x/y/z for a box, r/theta/z for a cylinder, lon/lat/height for an ellipsoid.
std::optional< CesiumTilesetJson::Padding > padding
 padding
std::string classProperty
 The class that property values conform to. The value shall be a class ID declared in the classes dictionary.
static constexpr const char * ExtensionName = "3DTILES_content_voxels"
Voxel content type.
Definition at line 18 of file ExtensionContent3dTilesContentVoxels.h.
int64_t CesiumTilesetJson::ExtensionContent3dTilesContentVoxels::getSizeBytes ( ) const
Definition at line 52 of file ExtensionContent3dTilesContentVoxels.h.
◆ classProperty
std::string CesiumTilesetJson::ExtensionContent3dTilesContentVoxels::classProperty
Definition at line 44 of file ExtensionContent3dTilesContentVoxels.h.
◆ dimensions
std::vector<int64_t> CesiumTilesetJson::ExtensionContent3dTilesContentVoxels::dimensions
Definition at line 33 of file ExtensionContent3dTilesContentVoxels.h.
◆ ExtensionName
const char* CesiumTilesetJson::ExtensionContent3dTilesContentVoxels::ExtensionName = "3DTILES_content_voxels"
Definition at line 27 of file ExtensionContent3dTilesContentVoxels.h.
◆ padding
std::optional<CesiumTilesetJson::Padding> CesiumTilesetJson::ExtensionContent3dTilesContentVoxels::padding
padding
Definition at line 38 of file ExtensionContent3dTilesContentVoxels.h.
const char* CesiumTilesetJson::ExtensionContent3dTilesContentVoxels::TypeName
Initial value:
"ExtensionContent3dTilesContentVoxels"
Definition at line 23 of file ExtensionContent3dTilesContentVoxels.h.
