CesiumTilesetJson::Padding Struct Referencefinal
The padding property specifies how many rows of attribute data in each dimension come from neighboring grids. More...
#include <CesiumTilesetJson/Padding.h>
Inheritance diagram for CesiumTilesetJson::Padding:
std::vector< int64_t > before
 before
std::vector< int64_t > after
 after
static constexpr const char * TypeName = "Padding"
Definition at line 16 of file Padding.h.
int64_t CesiumTilesetJson::Padding::getSizeBytes ( ) const
Definition at line 39 of file Padding.h.
◆ after
std::vector<int64_t> CesiumTilesetJson::Padding::after
after
Definition at line 31 of file Padding.h.
◆ before
std::vector<int64_t> CesiumTilesetJson::Padding::before
before
Definition at line 26 of file Padding.h.
const char* CesiumTilesetJson::Padding::TypeName = "Padding"
Definition at line 21 of file Padding.h.
