CesiumTilesetJson::Extension3dTilesBoundingVolumeS2 Struct Referencefinal
3D Tiles extension for S2 bounding volumes. More...
#include <CesiumTilesetJson/Extension3dTilesBoundingVolumeS2.h>
Inheritance diagram for CesiumTilesetJson::Extension3dTilesBoundingVolumeS2:
std::string token
 A hexadecimal representation of the S2CellId. Tokens shall be lower-case, shall not contain whitespace and shall have trailing zeros stripped.
double minimumHeight = double()
 The minimum height of the tile, specified in meters above (or below) the WGS84 ellipsoid.
double maximumHeight = double()
 The maximum height of the tile, specified in meters above (or below) the WGS84 ellipsoid.
static constexpr const char * TypeName = "Extension3dTilesBoundingVolumeS2"
static constexpr const char * ExtensionName = "3DTILES_bounding_volume_S2"
Definition at line 14 of file Extension3dTilesBoundingVolumeS2.h.
int64_t CesiumTilesetJson::Extension3dTilesBoundingVolumeS2::getSizeBytes ( ) const
Definition at line 49 of file Extension3dTilesBoundingVolumeS2.h.
◆ ExtensionName
const char* CesiumTilesetJson::Extension3dTilesBoundingVolumeS2::ExtensionName = "3DTILES_bounding_volume_S2"
Definition at line 22 of file Extension3dTilesBoundingVolumeS2.h.
◆ maximumHeight
double CesiumTilesetJson::Extension3dTilesBoundingVolumeS2::maximumHeight = double()
Definition at line 41 of file Extension3dTilesBoundingVolumeS2.h.
◆ minimumHeight
double CesiumTilesetJson::Extension3dTilesBoundingVolumeS2::minimumHeight = double()
Definition at line 35 of file Extension3dTilesBoundingVolumeS2.h.
◆ token
std::string CesiumTilesetJson::Extension3dTilesBoundingVolumeS2::token
Definition at line 29 of file Extension3dTilesBoundingVolumeS2.h.
const char* CesiumTilesetJson::Extension3dTilesBoundingVolumeS2::TypeName = "Extension3dTilesBoundingVolumeS2"
Definition at line 19 of file Extension3dTilesBoundingVolumeS2.h.
