Extension3dTilesBoundingVolumeS2.h
8#include <string>
9
10namespace Cesium3DTiles {
14struct CESIUM3DTILES_API Extension3dTilesBoundingVolumeS2 final
19 static constexpr const char* TypeName = "Extension3dTilesBoundingVolumeS2";
22 static constexpr const char* ExtensionName = "3DTILES_bounding_volume_S2";
23
29 std::string token;
30
35 double minimumHeight = double();
36
41 double maximumHeight = double();
42
49 int64_t getSizeBytes() const {
50 int64_t accum = 0;
51 accum += int64_t(sizeof(Extension3dTilesBoundingVolumeS2));
53 int64_t(sizeof(CesiumUtility::ExtensibleObject));
54 accum += int64_t(this->token.capacity() * sizeof(char));
55 return accum;
56 }
57};
58} // namespace Cesium3DTiles
Classes for using 3D Tiles.
Definition Buffer.h:7
std::string token
A hexadecimal representation of the S2CellId. Tokens shall be lower-case, shall not contain whitespac...
The maximum height of the tile, specified in meters above (or below) the WGS84 ellipsoid.
The minimum height of the tile, specified in meters above (or below) the WGS84 ellipsoid.
