An object defining the values of an enum.
More...
#include <CesiumTilesetJson/Enum.h>
| | Calculates the size in bytes of this object, including the contents of all collections, pointers, and strings. This will NOT include the size of any extensions attached to the object. Calling this method may be slow as it requires traversing the object's entire structure.
| template<typename T> |
| | Checks if an extension exists given its static type.
| | Gets an extension given its static type.
| | Gets a generic extension with the given name as a CesiumUtility::JsonValue.
| template<typename T, typename... ConstructorArgumentTypes> |
| | Adds a statically-typed extension to this object.
| | Removes a statically-typed extension from this object.
| | Calculates the size in bytes of this ExtensibleObject, including all of its extras but NOT including its extensions. Calling this method may be slow as it requires traversing the entire object.
| static constexpr const char * | TypeName = "Enum" |
| | The original name of this type.
Definition at line 17 of file Enum.h.
◆ getSizeBytes()
| int64_t CesiumTilesetJson::Enum::getSizeBytes |
const |
Definition at line 83 of file Enum.h.
◆ description
| std::optional<std::string> CesiumTilesetJson::Enum::description |
The description of the enum.
Definition at line 61 of file Enum.h.
◆ name
| std::optional<std::string> CesiumTilesetJson::Enum::name |
The name of the enum, e.g. for display purposes.
Definition at line 56 of file Enum.h.
◆ TypeName
| const char* CesiumTilesetJson::Enum::TypeName = "Enum" |
Definition at line 22 of file Enum.h.
◆ values
An array of enum values. Duplicate names or duplicate integer values are not allowed.
Definition at line 75 of file Enum.h.
◆ valueType
The type of the integer enum value.
Known values are defined in ValueType.
Definition at line 69 of file Enum.h.
- /home/runner/work/cesium-native/cesium-native/CesiumTilesetJson/generated/include/CesiumTilesetJson/Enum.h
