CesiumTilesetJson::BufferSpec Struct Reference
A buffer is a binary blob. It is either the binary chunk of the subtree file, or an external buffer referenced by a URI. More...
#include <CesiumTilesetJson/BufferSpec.h>
Inheritance diagram for CesiumTilesetJson::BufferSpec:
CesiumUtility::ExtensibleObject CesiumTilesetJson::Buffer
std::optional< std::string > uri
 The URI (or IRI) of the file that contains the binary buffer data. Relative paths are relative to the file containing the buffer JSON. uri is required when using the JSON subtree format and not required when using the binary subtree format - when omitted the buffer refers to the binary chunk of the subtree file. Data URIs are not allowed.
int64_t byteLength = int64_t()
 The length of the buffer in bytes.
 The name of the buffer.
static constexpr const char * TypeName = "Buffer"
Protected Member Functions
 BufferSpec ()=default
Friends
struct Buffer
Definition at line 17 of file BufferSpec.h.
int64_t CesiumTilesetJson::BufferSpec::getSizeBytes ( ) const
Definition at line 49 of file BufferSpec.h.
◆ Buffer
friend struct Buffer
friend
Definition at line 69 of file BufferSpec.h.
◆ byteLength
int64_t CesiumTilesetJson::BufferSpec::byteLength = int64_t()
Definition at line 36 of file BufferSpec.h.
◆ name
std::optional<std::string> CesiumTilesetJson::BufferSpec::name
Definition at line 41 of file BufferSpec.h.
const char* CesiumTilesetJson::BufferSpec::TypeName = "Buffer"
Definition at line 22 of file BufferSpec.h.
◆ uri
std::optional<std::string> CesiumTilesetJson::BufferSpec::uri
Definition at line 31 of file BufferSpec.h.
