Options for WebMapTileServiceRasterOverlay. More...
#include <CesiumRasterOverlays/WebMapTileServiceRasterOverlay.h>
| std::optional< std::string > | format |
| The MIME type for images to retrieve from the server. | |
| std::vector< std::string > | subdomains |
The subdomains to use for the {s} placeholder in the URL template. | |
| std::optional< std::string > | credit |
| A credit for the data source, which is displayed on the canvas. | |
| std::string | layer |
| The layer name for WMTS requests. | |
| std::string | style |
| The style name for WMTS requests. | |
| std::string | tileMatrixSetID |
| The identifier of the TileMatrixSet to use for WMTS requests. | |
| std::optional< std::vector< std::string > > | tileMatrixLabels |
| A list of identifiers in the TileMatrix to use for WMTS requests, one per TileMatrix level. | |
| std::optional< uint32_t > | minimumLevel |
| The minimum level-of-detail supported by the imagery provider. | |
| std::optional< uint32_t > | maximumLevel |
| The maximum level-of-detail supported by the imagery provider. | |
| std::optional< CesiumGeometry::Rectangle > | coverageRectangle |
| The CesiumGeometry::Rectangle, in radians, covered by the image. | |
| std::optional< CesiumGeospatial::Projection > | projection |
| The CesiumGeospatial::Projection that is used. | |
| std::optional< CesiumGeometry::QuadtreeTilingScheme > | tilingScheme |
| The CesiumGeometry::QuadtreeTilingScheme specifying how the ellipsoidal surface is broken into tiles. | |
| std::optional< std::map< std::string, std::string > > | dimensions |
| A object containing static dimensions and their values. | |
| std::optional< uint32_t > | tileWidth |
| Pixel width of image tiles. | |
| std::optional< uint32_t > | tileHeight |
| Pixel height of image tiles. | |
Definition at line 20 of file WebMapTileServiceRasterOverlay.h.
| std::optional<CesiumGeometry::Rectangle> CesiumRasterOverlays::WebMapTileServiceRasterOverlayOptions::coverageRectangle |
Definition at line 84 of file WebMapTileServiceRasterOverlay.h.
| std::optional<std::string> CesiumRasterOverlays::WebMapTileServiceRasterOverlayOptions::credit |
Definition at line 40 of file WebMapTileServiceRasterOverlay.h.
| std::optional<std::map<std::string, std::string> > CesiumRasterOverlays::WebMapTileServiceRasterOverlayOptions::dimensions |
Definition at line 100 of file WebMapTileServiceRasterOverlay.h.
| std::optional<std::string> CesiumRasterOverlays::WebMapTileServiceRasterOverlayOptions::format |
Default value is "image/jpeg"
Definition at line 27 of file WebMapTileServiceRasterOverlay.h.
| std::string CesiumRasterOverlays::WebMapTileServiceRasterOverlayOptions::layer |
Definition at line 45 of file WebMapTileServiceRasterOverlay.h.
| std::optional<uint32_t> CesiumRasterOverlays::WebMapTileServiceRasterOverlayOptions::maximumLevel |
Default value is 25.
Definition at line 78 of file WebMapTileServiceRasterOverlay.h.
| std::optional<uint32_t> CesiumRasterOverlays::WebMapTileServiceRasterOverlayOptions::minimumLevel |
Take care when specifying this that the number of tiles at the minimum level is small, such as four or less. A larger number is likely to result in rendering problems. Default value is 0.
Definition at line 71 of file WebMapTileServiceRasterOverlay.h.
| std::optional<CesiumGeospatial::Projection> CesiumRasterOverlays::WebMapTileServiceRasterOverlayOptions::projection |
Definition at line 89 of file WebMapTileServiceRasterOverlay.h.
| std::string CesiumRasterOverlays::WebMapTileServiceRasterOverlayOptions::style |
Definition at line 50 of file WebMapTileServiceRasterOverlay.h.
| std::vector<std::string> CesiumRasterOverlays::WebMapTileServiceRasterOverlayOptions::subdomains |
If this parameter is a single string, each character in the string is a subdomain. If it is an array, each element in the array is a subdomain.
Definition at line 35 of file WebMapTileServiceRasterOverlay.h.
| std::optional<uint32_t> CesiumRasterOverlays::WebMapTileServiceRasterOverlayOptions::tileHeight |
Default value is 256
Definition at line 114 of file WebMapTileServiceRasterOverlay.h.
| std::optional<std::vector<std::string> > CesiumRasterOverlays::WebMapTileServiceRasterOverlayOptions::tileMatrixLabels |
Definition at line 61 of file WebMapTileServiceRasterOverlay.h.
| std::string CesiumRasterOverlays::WebMapTileServiceRasterOverlayOptions::tileMatrixSetID |
Definition at line 55 of file WebMapTileServiceRasterOverlay.h.
| std::optional<uint32_t> CesiumRasterOverlays::WebMapTileServiceRasterOverlayOptions::tileWidth |
Definition at line 107 of file WebMapTileServiceRasterOverlay.h.
| std::optional<CesiumGeometry::QuadtreeTilingScheme> CesiumRasterOverlays::WebMapTileServiceRasterOverlayOptions::tilingScheme |
Definition at line 95 of file WebMapTileServiceRasterOverlay.h.
