Options for tile map service accesses. More...
#include <CesiumRasterOverlays/TileMapServiceRasterOverlay.h>
| std::optional< std::string > | fileExtension |
| The file extension for images on the server. | |
| std::optional< std::string > | credit |
| A credit for the data source, which is displayed on the canvas. | |
| std::optional< uint32_t > | minimumLevel |
| The minimum level-of-detail supported by the imagery provider. | |
| std::optional< uint32_t > | maximumLevel |
| The maximum level-of-detail supported by the imagery provider. | |
| std::optional< CesiumGeometry::Rectangle > | coverageRectangle |
| The CesiumGeometry::Rectangle, in radians, covered by the image. | |
| std::optional< CesiumGeospatial::Projection > | projection |
| The CesiumGeospatial::Projection that is used. | |
| std::optional< CesiumGeometry::QuadtreeTilingScheme > | tilingScheme |
| The CesiumGeometry::QuadtreeTilingScheme specifying how the ellipsoidal surface is broken into tiles. | |
| std::optional< uint32_t > | tileWidth |
| Pixel width of image tiles. | |
| std::optional< uint32_t > | tileHeight |
| Pixel height of image tiles. | |
| std::optional< bool > | flipXY |
| An otion to flip the x- and y values of a tile map resource. | |
Definition at line 19 of file TileMapServiceRasterOverlay.h.
| std::optional<CesiumGeometry::Rectangle> CesiumRasterOverlays::TileMapServiceRasterOverlayOptions::coverageRectangle |
Definition at line 51 of file TileMapServiceRasterOverlay.h.
| std::optional<std::string> CesiumRasterOverlays::TileMapServiceRasterOverlayOptions::credit |
Definition at line 29 of file TileMapServiceRasterOverlay.h.
| std::optional<std::string> CesiumRasterOverlays::TileMapServiceRasterOverlayOptions::fileExtension |
Definition at line 24 of file TileMapServiceRasterOverlay.h.
| std::optional<bool> CesiumRasterOverlays::TileMapServiceRasterOverlayOptions::flipXY |
Older versions of gdal2tiles.py flipped X and Y values in tilemapresource.xml. Specifying this option will do the same, allowing for loading of these incorrect tilesets.
Definition at line 81 of file TileMapServiceRasterOverlay.h.
| std::optional<uint32_t> CesiumRasterOverlays::TileMapServiceRasterOverlayOptions::maximumLevel |
This will be std::nullopt if there is no limit.
Definition at line 45 of file TileMapServiceRasterOverlay.h.
| std::optional<uint32_t> CesiumRasterOverlays::TileMapServiceRasterOverlayOptions::minimumLevel |
Take care when specifying this that the number of tiles at the minimum level is small, such as four or less. A larger number is likely to result in rendering problems.
Definition at line 38 of file TileMapServiceRasterOverlay.h.
| std::optional<CesiumGeospatial::Projection> CesiumRasterOverlays::TileMapServiceRasterOverlayOptions::projection |
Definition at line 56 of file TileMapServiceRasterOverlay.h.
| std::optional<uint32_t> CesiumRasterOverlays::TileMapServiceRasterOverlayOptions::tileHeight |
Definition at line 72 of file TileMapServiceRasterOverlay.h.
| std::optional<uint32_t> CesiumRasterOverlays::TileMapServiceRasterOverlayOptions::tileWidth |
Definition at line 67 of file TileMapServiceRasterOverlay.h.
| std::optional<CesiumGeometry::QuadtreeTilingScheme> CesiumRasterOverlays::TileMapServiceRasterOverlayOptions::tilingScheme |
Definition at line 62 of file TileMapServiceRasterOverlay.h.
