cesium-native 0.67.0
A common set of query parameters used across list operations in the Bentley API. More...
#include <CesiumITwinClient/Connection.h>
| void | addToQuery (CesiumUtility::UriQuery &uriQuery) const |
| Adds the parameters in this object to the provided URI query string. | |
| void | addToUri (CesiumUtility::Uri &uri) const |
| Adds the parameters in this object to the query of the provided URI. | |
| std::optional< std::string > | search |
| A search string to use to limit results. Not used by all endpoints. | |
| std::optional< std::string > | orderBy |
| Used to order the results. | |
| std::optional< uint32_t > | top |
| Limits the number of items that can be returned. | |
| std::optional< uint32_t > | skip |
| Requests that this number of items in the results will be skipped and not returned. | |
Definition at line 33 of file Connection.h.
| std::optional<std::string> CesiumITwinClient::QueryParameters::orderBy |
Ascending or descending order can be selected with the asc and desc keywords. Ordering by multiple properties at a time is supported: name desc,createdDateTime desc.
The set of properties that orderBy can reference is endpoint-specific.
Definition at line 48 of file Connection.h.
| std::optional<std::string> CesiumITwinClient::QueryParameters::search |
Definition at line 38 of file Connection.h.
| std::optional<uint32_t> CesiumITwinClient::QueryParameters::skip |
Definition at line 62 of file Connection.h.
| std::optional<uint32_t> CesiumITwinClient::QueryParameters::top |
For example, top = 50 would return only the first 50 items. The limit is 1,000.
Definition at line 56 of file Connection.h.
