CesiumGltf::MetadataConversions< float, std::string > Struct Reference
Converts from a std::string to a float. More...
static std::optional< float > convert (const std::string &from)
 Converts a std::string to a float. This assumes that the entire std::string represents the number, not just a part of it.
static std::optional< float > convert (std::string)
Definition at line 407 of file MetadataConversions.h.
◆ convert() [1/2]
static std::optional< float > CesiumGltf::MetadataConversions< float, std::string >::convert ( const std::string & from)
inlinestatic
This returns std::nullopt if no number is parsed from the string.
fromThe std::string to parse from.
Definition at line 416 of file MetadataConversions.h.
◆ convert() [2/2]
static std::optional< float > CesiumGltf::MetadataConversions< float, std::string, void >::convert ( std::string )
inlinestatic
