CesiumGltf::MetadataConversions< float, double > Struct Reference
Converts from a double to a float. More...
static std::optional< float > convert (double from)
 Converts a double to a float. The value may lose precision during conversion.
static std::optional< float > convert (double)
Definition at line 386 of file MetadataConversions.h.
◆ convert() [1/2]
static std::optional< float > CesiumGltf::MetadataConversions< float, double >::convert ( double from)
inlinestatic
If the value is outside the range of a float, std::nullopt is returned.
fromThe double value to be converted.
Definition at line 395 of file MetadataConversions.h.
◆ convert() [2/2]
static std::optional< float > CesiumGltf::MetadataConversions< float, double, void >::convert ( double )
inlinestatic
