CesiumGltf::MetadataConversions< bool, std::string > Struct Reference
Converts from std::string to a bool. More...
static std::optional< bool > convert (const std::string &from)
 Converts the contents of a std::string to a boolean.
static std::optional< bool > convert (std::string)
Definition at line 109 of file MetadataConversions.h.
◆ convert() [1/2]
static std::optional< bool > CesiumGltf::MetadataConversions< bool, std::string >::convert ( const std::string & from)
inlinestatic
"0", "false", and "no" (case-insensitive) are converted to false, while "1", "true", and "yes" are converted to true. All other strings will return std::nullopt.
fromThe std::string to convert from.
Definition at line 120 of file MetadataConversions.h.
◆ convert() [2/2]
static std::optional< bool > CesiumGltf::MetadataConversions< bool, std::string, void >::convert ( std::string )
inlinestatic
